Strange one
Anyone had this before ?
Fabia MK2 Greenline in for MOT today . Failed on rear brake imbalance . Not a happy chappy on hearing this as previous week had done my usual yearly strip and clean brakes all round . Typically on last corner found a leaking wheel cylinder . Changed it , bled brakes up , adjusted handbrake .
Presumed MOT failure was down to me over adjusting handbrake cable or forgetting to rough up / sandpaper shoes one side . Left car with garage to sort , 5 hours later done , tested , passed .
Reason for imbalance ? Other side wheel cylinder leaking ! Definitely wasn't last week as I'd checked under seals .
So question is , if you change one side does that put more pressure on other older cylinder causing possible failure ?
Well yes. And answering the supplementary in advance when you change the clutch slave that puts more pressure on the clutch master with similar effects.
  • Haha 1
So, does that mean we should change both sides when finding a single leaking wheel cylinder?
Hydraulics is not your strong point Paws5Thot 😁
No!
I have changed one side and never had a leak on the other side.
The pressure in the system does not change just because it is now "more" contained. There is nothing to amplify the pressure.
The second leak would have been bad luck.
Edited by 26DIPP
  • Like 2
