Spare wheel help
Hi all my daughter has just bought a 2019 fabia that has the useless foam in the boot but no spare, I want to find her a 15" spare wheel or space saver without spending loads so just wondering has the 5 stud pattern changed recently or am I OK in getting an earlier 5 stud wheel????, thanks
I'd assume this would do the trick :)
Thanks for that but I'm about 250 miles away.
I've previously bought a spare wheel on here and the seller helpfully wrapped in in plastic and I arranged my own courier.
Can't hurt to ask
Assuming the site has correct info it shows 2019 Fabias as - https://www.wheel-size.com/size/skoda/fabia/
  • Bolt Pattern (PCD): 5x100
  • Center Bore / Hub Bore: 57.1 mm
  • Thread Size: M14 x 1.5
Which is the same as my wife's 2015 Fabia.
If you're getting an actual spare 'get-you-home' wheel (and) kit then I recommend also adding in to it two of these wheel alignment guide tool, mount hanger bolts/studs to make roadside, or at home, wheel changes easier and less injurious to your back (cos of them bl**dy stupid wheel bolts instead of studs). - https://www.ebay.co.uk/itm/334375280678
Don't let your daughter be like most drivers and have the spare below correct inflation for use (or flat) by having her check its pressure regularly same as for the other four tyres.
Thankyou that's perfect
