Databus error
Had a very strange fault pop up on my 64 octavia 1.6d dsg
Driving along normal after leaving home 5 minutes into the journey a stability control system error came up on the dash and the yellow warning light came on then I had no drive as if it had dropped into neutral then the message tyre monitoring no data.
Pulled into a layby car still runs put it in park and it would not come back out of park.
Turned it off and it refused to start giving a message put vehicle in park or neutral to start.
Turned it off for 30 seconds and plugged obd11 in tried to start it and all started and getting all the gears.
Checked the fault codes and had one for engine brakes gearbox ect 17 in total all saying same thing databus error.
Any ideas what can cause this?
Get the battery and alternator voltages checked first.
^^^^ and check battery terminal connections.
The voltage showing when running according to the obd11 app is around 14.4 volts
Err...no, that's not what was asked. Check the battery voltage and do a CCA EN test to check whether the battery is failing on you. Anything below 20% of the CCA EN value of the battery...it's failing and needs replacing.
Sorry was just giving the info I had to hand.
Stability control error came up again last night but no loss of drive this time but got a fault code lost communication with tcm
Definitely check the battery voltage BEFORE starting up in the morning and (if possible) get a battery CCA test done.
Have got a new battery to try as the one fitted at moment is the oem one so it's coming up on 10 years old now
On a side note the car has always suffered from the dsg gear selector micro switch fault ( dealer refused to replace under warranty when I brought it 7 years ago) could this be driving the tcm crazy?
More likely the 10 year old battery...
I didn't have access to a battery tester so decided to errr on the side of caution and fit a new agm battery ( slightly higher CCA and higher overall ampage than to 10 year old one.
I coded the new battery went for a quick drive to set steering and tire pressure warnings ect and checked the charging voltage using the obd11 app and it was charging at 13.4 not the 14.6 to 8 that the old battery was charging at.
Fingers crossed it has done the trick will update if it gets me to work OK
Correct charging voltage for AGM is around 14.4 - 14.6 (I.e. a little higher than a flooded LA battery) but your original battery would almost certainly have been the issue.
If the new battery was pretty well charged then the BMS won't need to charge at the higher voltage to charge to battery to it's target of 80% SoC.
Quick question the original battery was a varta but when I coded the new one the make was down as JCB and the type was fleece not agm?
Actual manufacturer ID is not critical, fleece is the term VW use for AGM.
New serial number can simply be a one digit increment of previous number entered.
Daft I know but why would my brakes feel better after changing the battery?
10 year old car battery.  Yerr - think it is the battery in that case.  You're lucky if you can generally get 5-7 years.  10 years is pushing the envelope at bit.  Don't forget to get it coded in if your car has stop/start.
Edited by varaderoguy
Nope didn't fix it now broke down again stuck in gear even AA man can't get it out of park
Did you code in the battery?  Okay - so if you are stuck in gear, there is a release mechanism (look in the manual) on how to release the gearbox if its stuck in Drive/Reverse.  What we haven't had is a proper scan. All the previous symptoms fitted a failed battery. It could be the mechatronics unit that has failed, in which case - go speak with Darkside Developments and get a replacement board.
https://www.darksidedevelopments.co.uk/products/0am-dq200-dsg-7-speed-mechatronic-repair-kit-2010-onwards.html
Got it towed home after I got the gear surround off. Got it home and it started and drove ok but now got to work out what to do now.
I think I have a full scan off obd11 but need to find it
OBDeleven vehicle history log
Date: 2024-08-08 20:41
    VIN: TMBKG7NE4F0061913
    Car: Skoda Octavia
    Year: 2015
    Body type: Estate
    Engine: CLHA
    Mileage: 251072 KM
Fault
    Control unit: 01 Engine
    Active faults: 2
    Inactive faults: 0
    System description: R4 1,6L EDC
    Software number: 04L906021N
    Software version: 6547
    Hardware number: 04L907309B
    Hardware version: H22
    ODX name: EV_ECM16TDI01104L906021N
    ODX version: 002011
    Faults:
        U112300 - Databus error value received
            static
                Mileage: 251072 km
                Priority: 6
                Malfunction frequency counter: 1
                Unlearning counter: 255
                Engine speed: 0.00 1/min
                Normed load value: 0.0 %
                Vehicle speed: 0 km/h
                Coolant temperature: 89 °C
                Intake air temperature: 83 °C
                Ambient air pressure: 1000 mbar
                Voltage terminal 30: 12.880 V
                Dynamic environmental data: 20962817E0000017DD0417DE000011870000
        U010100 - Lost Communication with TCM
            static
                Date: 2024-08-08 13:31:03
                Mileage: 251070 km
                Priority: 2
                Engine speed: 3637.00 1/min
                Normed load value: 49.0 %
                Vehicle speed: 122 km/h
                Intake air temperature: 122 °C
                Ambient air pressure: 1010 mbar
                Voltage terminal 30: 13.320 V
                Dynamic environmental data: 209628111D271011A604F417E202100D0712D5000012000002117D2710
    Mileage: 251072 km
    Date: 2024-08-08 13:37
Fault
    Control unit: 03 Brakes
    Active faults: 3
    Inactive faults: 0
    System description: ESC
    Software number: 5Q0907379K
    Software version: 0371
    Hardware number: 5Q0907379F
    Hardware version: H31
    Serial number: 62004000000156
    ODX name: EV_Brake1UDSContiMK100ESP
    ODX version: 033001
    Faults:
        U112100 - Databus missing message
            static
                Mileage: 251070 km
                Priority: 6
                Malfunction frequency counter: 3
                Unlearning counter: 143
                Freezeframes: 0000801812000000BA7800010000000000000000000000
            static
                Date: 2024-08-08 13:31:04
                Mileage: 251070 km
                Priority: 6
                Freezeframes: 0002801832000000BA7800010000000000000000000000
        C114602 - Tire pressure monitoring display Signal error
            static
                Date: 2024-08-08 13:31:13
                Mileage: 251070 km
                Priority: 6
                Freezeframes: 0002801812000000BA6F00000000000000000000000000
    Mileage: 251072 km
Fault
    Control unit: 08 Air Conditioning
    Active faults: 0
    Inactive faults: 0
    System description: Climatronic
    Software number: 5E0907044K
    Software version: 0907
    Hardware number: 5E0907044K
    Hardware version: H03
    ODX name: EV_ACClimaBHBVW37X
    ODX version: 003017
    Faults:
        No trouble codes found
    Mileage: 251072 km
Fault
    Control unit: 15 Airbag
    Active faults: 0
    Inactive faults: 0
    System description: Airbag VW20
    Software number: 3Q0959655AC
    Software version: 0189
    Hardware number: 3Q0959655AC
    Hardware version: 012
    Serial number: 003P4PES8HE9
    ODX name: EV_AirbaVW20TS6VW48X
    ODX version: 001116
    Faults:
    Mileage: 251072 km
Fault
    Control unit: 16 Steering Column
    Active faults: 0
    Inactive faults: 0
    System description: Lenks. Modul
    Software number: 5Q0953507DH
    Software version: 0110
    Hardware number: 5Q0953549C
    Hardware version: 002
    Serial number: 11081404401969
    ODX name: EV_SMLSKLOMQB
    ODX version: 017001
    Faults:
    Mileage: 251072 km
Fault
    Control unit: 17 Dashboard
    Active faults: 3
    Inactive faults: 0
    System description: KOMBI
    Software number: 5E0920981
    Software version: 5297
    Hardware number: 5E0920981
    Hardware version: 201
    ODX name: EV_DashBoardJCIMQBAB
    ODX version: 009003
    Faults:
        B201000 - No basic setting
            Intermittent
                Date: 2024-08-08 09:51:04
                Mileage: 251032 km
                Priority: 2
                Unlearning counter: 181
            static
                Mileage: 251070 km
                Priority: 6
        U111000 - Function restriction due to communication interruption
            static
                Date: 2024-08-08 01:40:56
                Mileage: 251021 km
                Priority: 6
                Unlearning counter: 141
    Mileage: 251072 km
Fault
    Control unit: 19 Gateway
    Active faults: 1
    Inactive faults: 0
    System description: GW MQB Low
    Software number: 5Q0907530R
    Software version: 1188
    Hardware number: 5Q0907530D
    Hardware version: 126
    Serial number: 0002288957
    ODX name: EV_GatewLear
    ODX version: 011016
    Faults:
            static
                Date: 2024-08-08 13:31:05
                Mileage: 251070 km
                Priority: 2
                Supply voltage, terminal 30: 13.7 V
                Terminal 15: On
    Mileage: 251072 km
Fault
    Control unit: 42 Driver Door
    Active faults: 0
    Inactive faults: 0
    System description: TSG FS
    Software number: 5Q4959393B
    Software version: 0014
    Hardware number: 5Q4959393B
    Hardware version: 009
    Serial number: 0000112117279
    ODX name: EV_DCUDriveSideEWMAXCONT
    ODX version: 006001
    Faults:
    Mileage: 251072 km
Fault
    Control unit: 44 Steering Assistance
    Active faults: 0
    Inactive faults: 0
    System description: EPS_MQB_ZFLS
    Software number: 5Q0909144P
    Software version: 1043
    Hardware number: 5Q0909144P
    Hardware version: 122
    ODX name: EV_SteerAssisMQB
    ODX version: 010031
    Faults:
    Mileage: 251072 km
Fault
    Control unit: 52 Passenger Door
    Active faults: 0
    Inactive faults: 0
    System description: TSG BFS
    Software number: 5Q4959392B
    Hardware number: 5Q4959392B
    Serial number: 0000112017869
    ODX name: EV_DCUPasseSideEWMAXCONT
    ODX version: 006001
    Faults:
    Mileage: 251072 km
Fault
    Control unit: 5F Multimedia
    Active faults: 0
    Inactive faults: 0
    System description: MU-S-D-ER
    Software number: 5E0035842A
    Software version: 0435
    Hardware number: 5E0035842A
    Hardware version: 041
    Serial number: S7E02307143726
    ODX name: EV_MUStd4CPASE
    ODX version: 002039
    Faults:
    Mileage: 251072 km
Fault
    Control unit: 69 Trailer Control
    Active faults: 0
    Inactive faults: 0
    System description: ConWysTrailer
    Software number: 5Q0907383E
    Software version: 0137
    Hardware number: 5Q0907383B
    Hardware version: H14
    Serial number: 00000181563668
    ODX name: EV_TrailFunctGener2Hella
    ODX version: 001005
    Faults:
    Mileage: 251072 km
Fault
    Control unit: 76 Parking Assistance
    Active faults: 2
    Inactive faults: 0
    System description: PARKHILFE 4K
    Software number: 5Q0919283D
    Software version: 0048
    Hardware number: 5Q0919283
    Hardware version: H10
    Serial number: 39231421001222
    ODX name: EV_EPHVA14AU3700000
    ODX version: 002022
    Faults:
            static
                Mileage: 251070 km
                Priority: 6
            Intermittent
                Mileage: 251070 km
                Priority: 6
    Mileage: 251072 km
Car sold not my problem anymore
