Octavia 4 (NX) Glove Box Cooling Retrofit
A quick guide for the Octavia 4 (NX) platform car for adding the glove box cooling, a simple mod, demonstrated here on a RHD UK car.
Tools Reqd:
T20 Torx screwdriver
Trim pry tool
Parts Reqd:
5E0816355 (Valve/Vent)
5E0816311  (Air Hose)
Skoda Parts Direct (in the UK) quoted me £28.58 for these.
Step 1 -  use trim pry tool to remove the passenger dash side panel. If you remove the airbag swich connector you'll likely get a fault code (definitely if you turn the ignition on with this disconnected), so have your VCDS/OBDEleven ready to reset this - or leave it connected.
Step 2 - undo the two screws shown with black arrows, releasing the side of the glove box.
Step 3 - unhook the glove box damper arm (orange arrow). Depress the tabs (green arrows) and allow the glove box to drop to its full extent. Undo the 3 screws at the top edge (black arrows).
Step 4 - undo the two screws underneath the glove box at each end. Gently pull on the glove box and release it from the dash. Undo the 3 cables (2x lights and 1x light switch on the damper arm).
Step 5 - squeeze the tab (green arrow) and pull the air distribution plenum towards you.
Step6 - remove rubber blanking cap.
Step 7  add hose.
Step 8 - refit plenum.
Step 9 - fit the vent to the existing cutout in the top of the glove box, and attach hose.
Step 10 - "Refitting is reverse of removal" as the Haynes manual used to say.
Enjoy cold air in the glove box! You'll note that whether the climate is set to Hot, or Cold, the glove box is always fed directly with cold air.
11.jpg.e39b9347f956f7ea30654a580c8c20ef.jpg12.jpg.1414c36a29b5dd5beb9e033514f44c8f.jpg
Hope this helps someone!
Edited by sunshinedave
Thanks for posting this - stumbled on this by accident looking for pictures behind the glovebox, and will for sure be added to my todo list!
  • 4 months later...
Tools Reqd:
Trim pry tool
Parts Reqd:
Step 7  add hose.
I made it... Works great.. Tks 👍
  • 9 months later...
What sort of temperature does it keep the glove box at? I am wondering if it is always the same temperature regardless of what you set the cabin temperature to.
  • 4 months later...
I've just registered in this forum to say thank you!
I recently bought a 2022 Octavia Sportline 2.0 TDI and although it came packed with extras, the glove box cooling was not part of it.
Did a search on google to see if it would be possible to fit it and it landed me here.
I got the parts from Aliexpress for 19.80 eur.
I followed you instructions and the installation went smoothly, no surprises, all as you described.
Mine is a left hand drive but everything was mirrored on right side of the car so, no issues there.
I did notice, while searching for the parts, that the valve and hose kit may be sold as left or right side but there is absolutely no difference. It is the same for both sides.
Thanks again for posting such detailed instructions.
