Fuse box 2023 Octavia Estate
I understand that the fuse box is behind the glove box.
Can someone advise how to remove the glove box. The car manual is very unclear. I have tried to follow the instructions with no success.
All suggestions gratefully received.
Open the glove box, then towards the back on the sides press in and release the plastic clips, but be careful as there is a device to
damp the opening and when you drop the lid down this device will drop out, but all you have to do is reinstall as you push the lid
back up
Hi Thanks for reply. My handbook says to first "release the box brake pull pin* which is shown on RHS of glove box and then press latches on inside to remove glovebox. So l don't release the pin. I can't move it.
Many thanks.
That is for a VW and the pull pin is on the opposite side but I have now released that pin. My retaining latches are different and less obvious. I will work on that later.
I release those tabs with a large screwdriver - just push the clips on the dashboard structure outwards from the lid and wiggle the glovebox past. Then do the other side.
Thanks everyone. I have now released the glove box and replaced the fuse. I blew the 12v outlet when using a badly wired camp bed pump.
I used a flat screwdriver to deflect the tabs as suggested above.
