Pressure sensor or not ? Glow plugs
Hi , Can anyone tell me if glow plug no 3 on my car is one with a built in pressure sensor , and if so would anyone know the part no please ?
2017 1.6 diesel
reg is FM66TOA if that helps
Thanks.
Edited by Benscab
  • Sponsor
Yes, assuming cyl 3 is the one that has the special plug. Part number is 03L 905 061G, superseded by 03L 905 061L. Latter is £138 + VAT at Skoda, for reference.
Edited by Breezy_Pete
Do you have any experience changing the glow plugs on the Vag Diesels?
I have an 184ps TDi (2014 vRS Octavia) with a glow plug 4 error.
Access to the plug seems straightforward but I've read alot about shearing the plug when trying to remove it...
Is it easy enough to do if you are careful & soak with a little WD40 before hand?
I was randomly looking at glowplug videos yesterday on YouTube looks straight forward “Skoda superb glow plugs replacement” “vw Passat glow plug replacement” should find loads then
Someone did use wd40 to release.
How many miles and has yours done? Seems glow plugs failing quite common now looking here, it is colder now though so being used harder I suppose
It's on my Octavia not the superb.
It's a 2014 184ps TDi.
I've done almost 250k km so can't complain really but was thinking I could save a few hundred CHF by doing it myself
2017 1.6 diesel
Thanks.
Hi, I have got the same issue with my Skoda superb 3v5. I.e. I need the glow plug with the pressure sensor and
the chassis number of my car is: TMBKH7NP9K7013548
any help would be appreciated if someone can supply the right part number?
 On eBay; 04L 905 061C is advertised as the compatible one?
But some eBay sellers are advertising the par number as 03L 905 061C
So I am a bit confused which one to go for?
Thanks in advance.
  • Sponsor
@mazzy960 your VIN brings up part number 03L 905 061K for the pressure sensing glow plug.
This was superseded on March 1st 2023 by 03L 905 061L. (£138 + VAT at Skoda)
Hi Breezy_Pete,
Thanks very much for your time and effort in order to identify my Skoda superb’s (3v5) Glow plug with pressure sensor?
i really appreciate it and once again I do thank you.
