Dynamic turn signal mirror light
I recieved them
I tested them, working fine.
  • Replies 55
  • Views 9k
  • Arrived today :-) Also with fake E sign ;-)
  • I think they will fit..
  • Hello, I am expecting these dynamic turn lights today. The installation procedure is almost the same as the previous Octavia model. Please watch the video below Install Dynamic LED Lights for m
27 minutes ago, Giannis20 said:
I recieved them
Looks great 👍🏼
Nice !
Well, i did the installation. One hour for both sides.
Looks great
Can you make a longer video using the parking lights, please
On 17/04/2025 at 09:59, Giannis20 said:
I recieved them
Hello
Works ok? Does it any light (error light) on the panel (virtual cockpit)?
New turn lights, working fine, no error messages on dashboard.
The light intensity is better than the OEM lights.
Great work Giannis! I sealed the cable and will install mine soon! They look amazing!
Was the installation hard?
thanks.
There is no hard step on the installation.
Here some photos from the procedure, i t might help someone.
Mirror removal:
2 screws
Clips for the upper part.
Front frame removal
Edited by Giannis20
Ok, mines are on as well. Important! From the inside you miss the blinker on the outer corner of the mirror. @Giannis20 can you confirm as well?
I would say it's the way it works.
Yes you are right. It is common on those dynamic turn lights. I have installed a similar one in my other car, a VW Polo, and it is also almost invisible there.
17 hours ago, Giannis20 said:
thanks.
Mirror removal:
2 screws
Front frame removal
Thank you for the pictures! Next weekend i will install mind :)
Thanks a lot for the feedback @Giannis20 . I did a full scan and I can confirm that it doesn't trigger any error in control units.
Edited by Mario_Delgado
Hello @Lukas_2611 ,
What product did you use to seal the cables?
Something similar to:
Liquid Insulating Tape Repair Rubber
https://a.aliexpress.com/_Eut4iWW
Thank you
10 hours ago, djmartzian said:
Hello @Lukas_2611 ,
Thank you
i used a black silicone. You just need to make sure that no moisture can get inside. So I think silicone can do this job very well.
On 24/04/2025 at 08:44, Giannis20 said:
How did you disassemble the unit without breaking? I think its really tough.. maybe i am doing something wrong..
Please be more specific. I don't understand which part do you mean.
I mean to dissamble the indicator unit out of the cover..
yes I understand.
It is a little difficult, because it is fastened in 3 places.
A little patience, start from the inner fastening, it comes out easily, the difficult part is the edge, that's where you need to be careful because the protrusion can break.
Edited by Giannis20
12 minutes ago, Giannis20 said:
yes I understand.
I broke this little part 4x times.. on the originals and on the new ones.. xD ..
So I ordered new running lights... they are on the way..
The running light units where also a little damaged on the edge.. so I hope the new ones are better..
I also recognized that the E sign was wrongly made.. so how its called.. upside down? Are yours in the right position?
Thanks for the pic.. I started at the edge.. so on the outer part.. maybe that was the mistake..
Edited by Lukas_2611
@Giannis20 is your E Sign in the correct position? :)
Sorry, i didn't understand what you mean.
There is a sign on the light unit.. 015 E 12345 or something like that. On my running lights it was upside down.. so when installed wrong pposition
ΟΚ, you mean the E sign
It's upside down, as you can see in the photo. But they work as they should.
