Battery coding with cheap OBDII dongle
I have just changed my battery from a Varta AGM battery (I believe this is the original) to a Bosch AGM battery. (2017 Superb 2.0TDi)
Can I do the battery registration with a cheap bluetooth OBDII (ELM327) from ebay, or do I need one of the expensive ones like OBDeleven or similar?
33 minutes ago, Orlinon said:
bluetooth OBDII
The bluetooth OBDII is just the interface between the car and the APP you might use.
Check if the APP supports new battery adaptation.
Thanks.  AG Falco
