Is your memory seat forever broken? READ THIS
So, there is a very commonly known fault that essentially bricks the memory profiles while leaving all the manual controls alone. This is shown to leave persistent faults for all the axis that failed to norm/standardize, usually the lumbar support up/down and in/out.
Well, as it turns out, i found out that through long coding i can tell the module that lumbar support is not installed and all the related faults will clear. THIS WILL MAKE THE LUMBAR SUPPORT STOP WORKING SO MAKE SURE TO LEAVE IT WHERE YOU WANT IT FOR THE FORESEEABLE FUTURE.
I'll make further tries later on to complete standardization/norming on these axes but for now i'm convinced it just ain't happening without a new module
Fiest open vcds, select the seat memory module, enter long coding and accept experimental coding information
Next, skip to byte 18 and 19 and untick "ldw/ldh_motor_installed" for each. Confirm and write the new long code. You should instantly hear a bong from the instrument cluster and you can set new presets by pressing "set", release then press any number. Personalization through kessy matching should also work now20250218_061719.thumb.jpg.0d53397baaba54a3ed456742997294a9.jpg20250218_061726.thumb.jpg.35a23553f7466f22baf08bab2973e87f.jpg
To gain back lumbar support controls, enable both again (and lose memory features)
Hi. I hope you can help me with this.
I did the long coding as suggested here using carscanner. I got 2 bongs. Lovely.
I can select seat adjustment to key in the menu. Lovely.
But it won’t save seat position. I’ve done the all the way forwards, all the way back etc. (and cracked my visor mirror in the process)
Still no joy.
The mirror setting for reversing works.
If I push and hold number 1 the mirror moves to a new position. But the seat doesn’t. So there is some memory stored.
It’s almost as if the set button doesn’t work.
I fear it may need a new module but that’s £220 plus coding! Any other thoughts?
Firmware Update, which Modul you have? Index A dont Support the Firmware Update
Do you get any other faults in the module? Memory works only if completely clear of any faults, even if historical. After that, SET, then 1/2/3 should store position. Mirrors will work even with the seat broken. If neither works you may have other problems
I have module A. Dammit
known problem...
Buy second Hand?
I don’t know. I only have carscanner not vcds and it doesn’t show faults on the set module I don’t think. I’ll have another look. Mirror may have worked previously I just didn’t know to leave the knob on L, but turning off the lumbar support coding worked in allowing some bongs
Edited by Binx1310
Ah it does. It says:
Car Scanner ELM OBD2
Version: 1.121.0/1.121.0/iOS
DTC report
Connection profile: Skoda MQB, PQ26: Diesel DPF var.1 [EA288]Date: 2/21/2026 10:16:27 PM
VIN: xxxxxxx
OBD-II
No DTC found.
36. Driver seat adjustment36. Driver seat adjustment
DTCs: 3
9654868 [0x935254] Archive (inactive)
B135254: Lumbar support fore/aft adjustment motor, No basic setting
lumbar_support_longitudinal_adjustment_motor_no_basic_setting
Status bits: 1
Priority: 4
Frequency: 1
Unlearning index: 172
Odometer: 198818 km
Date, time: 2025.11.27 21:34:06
Status: Confirmed
9654612 [0x935154] Archive (inactive)
B135154: Lumbar support height adjustment motor, No basic setting
lumbar_support_height_adjustment_motor_no_basic_setting
Status bits: 1
Priority: 4
Frequency: 1
Odometer: 198818 km
Date, time: 2025.11.27 21:34:07
Status: Confirmed
10489856 [0xA01000] Archive (inactive)
B2F0100: Development code 1
positioning_error
Status bits: 1
Priority: 7
Frequency: 1
Odometer: 198818 km
Status: Confirmed
Edited by Binx1310
15 minutes ago, Cairus said:
known problem...
Buy second Hand?
Yes. There is even cheaper Chinese copy but I’m not sure.
I can live without seat memory. Was hoping it was an easy/cheap fix!
For completeness I’ve undone the coding to reinstate the lumbar support as it didn’t gain anything. Now I know how the reverse mirror adjustment works, that works well now in the current condition too.
One for the long list when funds allow
Car Cost's Money!? 🤷
Yes. But I just meant I was comparing cost vs benefit. I can live without the seat memory function and spend the £250 it would cost to fix it on something else for now. And then get to it when other priorities have been completed.
Random continuation of this thread. I found in carscanner (strangely in the climate menu) the basic setting procedure for drivers seat. So went back to the long coding to remove lumbar control. Two bongs. Then did the basic setting procedure. Two bongs.
Checked and no trouble codes. I was starting to get hopeful that I had got round the problem.
Alas no. Still no memory function. Back to the long list for a new module!
  • 3 months later...
Thanks @Athrx I managed to solve this issue thanks to you and your brillant analysis. I have to add one point though: in order for this to work, make sure to delete error codes in this module before disabling lumbar controls.
Thanks. I found that deleting faults before will make them reappear instantly. Perhaps wipe before and after, for completion?
