44 - steering Reset to factory
Previous to this car had no faults or warning lights
Reset to factory settings now i can’t set steering angle or enter measuring blocks etc
Fault codes are
Steering Angle not set
end stops not learned
However VCDS states error or malfunction when trying to calibrate in Basic settings?
Looks like you like me learned the hard way to not play with settings.
I ended up in the same situation, the problem was I think bad instructions in VCDS when it was telling me to drive left and right at certain speeds whilst simultaneously patting my head and rubbing my stomach.
I think after tearing my hair out it resolved itself through normal driving, I'm sorry I can't recall more, what I did retain and will not forget is to ignore my curious nature when it says "what will happen if I do that?"
Hi, still at it then. 😣 If you can't or don't want to drive the car and can't get anyone with VCDS(?) experience on this then perhaps the old turn-it-uff-'n'-on-agen might get some of the car's computer bits out of a twist. What you asked about before, I used to suggest to try the following but often got slaughtered for the suggestion (it's not always about direct relationship but sometimes indirect with these computers, a problem can flow to elsewhere too).
Fully disconnect the battery, turn on the headlights (even though the battery is disconnected), get the two battery terminal leads joined to create a path for as many seconds as you see fit, if you want to then leave disconnected battery resting for a while, before reconnecting battery remember to turn off headlights.
As appropriate or as you prefer - start the car and go for a drive - or go through reset procedure - or plug scan tool back in to see if any values are back.
Obviously take all the usual care and cautions when doing above and consult the car's 'Owner's Manual' for what might be lost with battery disconnection, often it's just time of day clock in reality if prior to disconnecting you closed all powered windows and roof, also use 'Owner's Manual' to confirm disconnect and reconnect procedures.
The above might not cure your issue but it's a simple quick easy clean-hands thing to try and only recently another member tried battery disconnection and it might have cleared an engine light, done properly it can do no harm so perhaps worth a go at this stage.
Good luck.
Edited by nta16
typo
β€œnot to play with settings”
How are we supposed to fix things
It shouldn’t be this difficult to adapt the steering system, ABS speed sensors are working correctly, no fault codes where present before i reset
However
The car steering wasn’t driving as it left factory
Now ive reset all settings the power steering is working better than before and it’s possible to change assist parameters however the yellow dash lights are illuminated
When trying to set steering angle VCDS state malfunction or error in 03 -ABS or 44- steering
Ive just took it for a drive, it feels like the drivers side end stop is software controlled now but the passengers still feels like the tie rod end is taking the brunt of it
Assisted steering seems working fine on dynamic
Obviously feels unstable while driving as the Electronic stability fault light is still illuminated
Steering angle is still not set and stays at 0* while monitoring values
45 minutes ago, nta16 said:
Hi, still at it then. 😣 If you can't or don't want to drive the car and can't get anyone with VCDS(?) experience on this then perhaps the old turn-it-uff-'n'-on-agen might get some of the car's computer bits out of a twist. What you asked about before, I used to suggest to try of the following but often got slaughtered for the suggestion (it's not always about direct relationship but sometimes indirect with these computers, a problem can flow to elsewhere too).
Good luck.
It drives better than previously from the mechanics
Just hope no damage has been caused while the steering was heavy putting stress on the rack etc
I have a failing laptop battery thats not helping the situation either that should be resolved Monday or Tuesday
I’ll take it to an empty carpark and try again also could disconnect battery see if i can manually set the angle
Tla
I had not realised that you were the guy that replaced a lot of steering and suspension components to then suffer heavy steering but would not accept what was shouting out, the castor angle being well outside of the specification and instead was fixated about increasing the steering power assistance.
I bowed out then and am doing so again now, you have started several threads, I would not have commented had I realised what vehicle it was.
I don't think these vehicles have "software controlled end stops" that you attribute to them, they can be driven without the power steering working, I was towed recently in mine, the steering angles were exactly the same as when the power steering functions.
they do have software controlled end stops to say otherwise is either uneducated or ignorant
Just wondering if VCDS requires timeout changing/prolonging for measured values maybe the steering angle is looking for abs wheel sensor values but the car is stationary idk
Tbh pal idgaf if you want to help or not with the tone of your replies i’d hazard a guess your gatekeeping information or just thread bombing with no added value
When i find the resolution i’ll post it on here for everyone to learn from
Thank you for your observations.
That is no-no, the car battery and scan tool battery (if appropriate) both have to be in a reasonable state of charge and health and the scan tool program appropriate for your make, model an year of car (or VIN) and fully up to date before you plug the scan tool in otherwise you might get spurious readings and reports. Sorry, if I didn't put that before (I forget, I even had to check if it was you in the other thread I'd been on, before I put a link here for you to look at πŸ˜„), I thought would have but I might have forgot there.
Now the failing laptop battery may not have effected the reading but why would you chance it after all you've been through already.
As many more are now catching on battery state of charge and health are important to these modern cars with all their computer systems and programs, been like that particularly with the (not-so-clever) German marques for many years.
Edited by nta16
third attempt to edit well
Sorry @Skodacrazy , on re-reading my last post I hadn't worded it the way I meant (often happens with my typing).
I have edited to hopefully get it nearer to what I meant.
The way I look at it the car has one set of computer programs that can have errors and omissions and the scan tool has a different set of programs with errors and omissions so putting the two together you want to reduce the possibility and risk as much as possible of any more errors from power supplies.
I hope that makes sense.
You see the short comings of the scan tools in the videos I hope I put a link to (in the other thread I linked to).
See how you go Monday or Tuesday with a reliable laptop battery. Good Luck.
Edited by nta16
Hi all
so this car has a donor ECU none original to this vehicle would the VIN or Coding changed when i reset to steering -44 to factory ?
There is no other fault codes related to lost coding
Is this something VCDS can fix?
How did you find this out?
Its wrote in marker pen on the unit under the bonnet
Edited by Skodacrazy
In that case was everything working on the car before this need to sort the steering - I've not read other threads or have forgotten so don't know the history to this, for all I know you might have bought a crash car, perhaps a write-off and/or partially repaired.
If the ECU swap of computer stuff wasn't done fully or correctly then obviously that could be a big issue. I don't have the knowledge, experience or confidence to be other than very reluctant to try ECU swapping for myself let alone say anything about it to another and I've never used a VCDS (looks very ugly, nerdy, legacy system presentation to me) so at this point as they say on Dragon's Den I'm out. I can only wish you the best of luck with sorting this part of your process. Cheers.
Edited by nta16
typo
Have you done the obvious?
  • Check the steering angle output is plausible (0 in the middle and changes as you move the wheel)
  • Steering angle sensor basic settings (either in ABS or Steering)
  • Moved the wheel full left, then right, then center
In future, just post a full autoscan using copy and paste rather than pictures. It will give a fuller story and is easier to read πŸ™‚
One bit of advice I can give, generally hold your photo so that you get a landscape instead of portrait photo generally this gets more information in the photo for car matters and if you can narrow the left sidebar on the VCDS screen box the full line could be seen on "10736664 - Steering End Stops Not Learned" (SIC?) especially in landscape.
original car was steering perfectly, decided to fit new arb bushes & while on the ramp renew tie rods lower arms etc
alignment done
yes, previous to me resetting the steering angle would move from 0* + & -
no fault codes or lights
However i reset because when i looked at VCDS the steering assist was set to Unknown instead of auto comfort or dynamic
And the steering was still somewhat heavy,
after reset the steering assist is set to dynamic
however now the steering angle doesnt move from 0* & fault codes / amber lights
Thursday,13,March,2025,23:02:56:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 24.7.0.0
Data version: 20240715 DS356.3
www.Ross-Tech.com
VIN: TMBFJ6NH1F4503739 License Plate: 2014 TDI 1.6
Mileage: 87270km-54227mi Repair Order: full autoscan
Chassis Type: NH-SK25 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 44 56 77
VIN: TMBFJ6NH1F4503739 Mileage: 87270km-54227miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 LL HW: 03L 906 023 LK
Component: 1,6l R4 CR td H33 9972
Revision: --H33--- Serial number: CVN: 1F642B7C
Coding: 00114016002500080000
Shop #: WSC 73430 031 00046
ASAM Dataset: EV_ECM16TDI02103L906023LL 003010
ROD: EV_ECM16TDI02103L906023LK_SK25.rod
VCID: 7BF542EBF2E5694E96-802E
VINID: 91D4966867980561050031C324EEC2AE61
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 6R0-614-517-TRW460.clb
Part No SW: 6R0 614 517 BD HW: 6R0 614 517 BD
Component: EBC 460 ESP H08 0004
Serial number: A00HVBC
Coding: 4229481489B200BD424712D591A10080480900
Shop #: WSC 73430 031 00051
ASAM Dataset: EV_Brake1ESPAEntryTRW 002011
ROD: EV_Brake1ESPAEntryTRW.rod
VCID: 76E353DFC9C73426E9-8022
2 Faults Found:
0360 - Steering angle sensor
B1168 54 [10001001] - Missing Calibration / Basic Setting
MIL ON - Confirmed - Tested Since Memory Clear
0349 - Steering Angle Sensor
B1168 F2 [10001001] - Not Initialized
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Mileage: 87269 km
Date: 2025.03.13.
Time: 10:42:03
DTC: 00 01 5D
Address 08: Auto HVAC (J255) Labels: 6Q0-907-044.lbl
Part No SW: 5JA 907 044 HW: 5JA 907 044
Component: Climatronic H04 0104
Revision: A1001000 Serial number: 1310232A-0453
VCID: 78FF5DE7CBD34256FB-802C
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 P HW: 6R0 937 087
Component: BCM PQ25 H+4 H34 0411
Revision: BF034001 Serial number: 0581 340131030
Coding: 3C980B0000C92400920808306C0B0CC00E80400F608E0000020000004000
Shop #: WSC 73430 790 00051
VCID: 4A9BD72FE5BF00C65D-801E
Subsystem 1 - Part No: 5J0 951 172
Component: DWA-Sensor H0 H03 1211
Coding: 000000
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 3 - Part No: 5J0 951 172
Coding: 000000
Subsystem 4 - Part No SW: 5E0 919 719 F HW: 5E0 919 719 F
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000A1562111213
Coding: 820000
Address 10: Park/Steer Assist (J446) Labels:| 5JA-919-475.clb
Part No SW: 5JA 919 475 A HW: 5J0 919 475 A
Component: PARKHILFE 3K H11 0005
Revision: -------- Serial number: 32931335001844
Coding: 100003
ASAM Dataset: EV_EPHVA14SK25X0000 001002
ROD: EV_EPHVA14SK25X0000.rod
VCID: 4487F917CF9BD6B6A7-8010
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 34D 959 655 B HW: 34D 959 655 B
Component: AirbagVW20 004 0365
Serial number: 003K7R02G5GA Dataset Number: 5JA003t____ 0013
Coding: 88CCC00000000000540000C8008000000065
ASAM Dataset: EV_AirbaVW20SMEVW253 001108
ROD: EV_AirbaVW20SMEVW253.rod
VCID: 3467A9D79F3B663617-8060
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 410 412 13
Component: SideSensor_Df 003 0148
Serial number: 349650A25E3BFE059CFD
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: ----------- HW: 480 410 412 13
Component: SideSensor_Pf 003 0148
Serial number: 350650A25C5530A28E5E
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 480 411 212 13
Component: SideSensor_Dr 003 0148
Serial number: 351651A011334F32CFFJ
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 410 412 13
Component: SideSensor_Pr 003 0148
Serial number: 352650A25E35F8A52D6X
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5JA 920 940 E HW: 5JA 920 940 E
Component: KOMBI H04 0709
Serial number: 00000000000000
Coding: 411A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod
VCID: 3D718CF3AC71A77EE8-8068
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H34 0411
Revision: BF034001
Coding: 932300
VCID: 70EF65C7A3A31A1633-8024
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0709
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADB77AF8D7FE0C67D-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Component: SG EXT.PLAYER H19 0770
Revision: A1001003 Serial number: 7665586601
Coding: 030100
VCID: 2B55B2AB4A0539CE46-807E
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R2 909 144 R HW: 6R2 909 144 E
Component: EPS_TRW_ALow 321 3111
Serial number: CDCH0861 Dataset Number: 5JJ074t____ 0014
Coding: 0003
Shop #: WSC 46635 001 1048576
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_011.rod
VCID: 479DEE1BFEADFDAE42-8012
3 Faults Found:
1094656 - Steering angle sensor
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 59
Mileage: 87269 km
Date: 2025.03.13.
Time: 10:39:31
1073664 - Steering End Stops Not Learned
C10AC F0 [10001001] - Unknown Error Elaboration
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 59
Mileage: 87269 km
Date: 2025.03.13.
Time: 10:39:31
1073920 - Steering End Stops Not Learned
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 59
Mileage: 87269 km
Date: 2025.03.13.
Time: 10:39:31
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5J0 035 161 E HW: 5J0 035 161 E
Component: Radio-SWING 004 0001
Revision: -----04S Serial number: SKZ4Z2N1366436
Coding: 090004000007
VCID: 2447599727DBF6B687-8070
2 Faults Found:
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 87198 km
Time Indication: 0
Date: 2019.08.03.
Time: 19:07:50
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 87198 km
Time Indication: 0
Date: 2019.08.03.
Time: 19:07:50
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007665610250 Dataset Number: 7P6035730K 0001
Coding: 0200000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A7B87EFBD5F9046CD-806E
End-------------------------(Elapsed Time: 05:15)--------------------------
tia
If it was heavy and the only change was parts, it's likely something is incorrectly fitted...
It's not advised to reset a module as there is a good chance it'll wipe config data which will need ODIS to replace. This might be part of your issue but hopefully not.
Another VCDS user had similar fault codes and an independent with ODIS fixed it within minutes: https://forums.ross-tech.com/index.php?threads/31747/
Still, I'd be looking at which basic settings are shown in both the ABS and steering assist modules. You might need to do more than one thing to both initialise then calibrate the steering angle sensor. You can then move on to the end stops. Random example from online:
Just a quick thought I had before, by ECU I assume you mean ECM so do the numbers on the donor ECM/ECU match those that the VCDS shows, the programs and systems are so intertwined. If you didn't fit the donor you won't have the back up files to perhaps compare(?) from the original ECM/ECU with the donor settings.
And did you try auto comfort setting or going back to unknown to see if different or missing values appear.
No need to reply just thoughts I meant to put earlier.
Edited by nta16
missing word
Yeah I’ll probably take it to someone with ODIS to fix
Could also be this copy of VCDS not sure if its original
@nta16 The vis4vag.com does contain correct procedures, Coding information i just thought it would store a fault code for incorrect vin/long code
If you look at the several other threads created and specifically the 4 wheel alignment data (castor angle) you will observe that the OP is in denial of that and is seeking a software solution.
Edited by J.R.
But it drives fine now the power steering works near enough perfect, caster? it was febi lower arms probably not oem quality they were half the price of lemforder
Somehow the steering assist setting was corrupt displaying β€œunknown” instead of comfort/Auto/Dynamic ~ no idea why this happened
There was no fault codes or dash lights until i reset the steering assist module in VCDS
I’ll try and double check the vin/coding to the module’s if i get the chance however if ODIS can do this easily then i’ve had enough these new 2000’s cars are terrible bring back mk2 golfs
Good & bad news lol
Car EPS/ABS was fixed using ODIS
Steering was stronger less road vibration through steering wheel, ABS & traction control working, slight veering to left though? Steering Torque?
However Driving back the car felt not great
checking the autoscan it had faults everywhere nearly every module (as the photo)
So I cleared the DTC’s and back to square one dash lights back on
Lucky i saved auto-scan before clearing anything, nothing seems different apart from an extra fault code B200500 & WS number
On 15/03/2025 at 21:15, Skodacrazy said:
mk2 golfs
To me the start of overweight mediums sized VWs, the Mk1 GTi remains the only VW, old or new, that I've ever fancied a drive of or owning. Until a couple of years ago my every day car for the previous 16 years was a car from 1973. πŸ™ƒ
Communications errors so for those you need to check and diagnosis wires, connections, connectors and modules for power and communication signals, as in the link to the professional diagnostics chap's videos, scan tool, scope, multimeter and and load bulb as required.
If B200500 is correct does it really effect a 2014 car, I've no idea but if it does, from a quick read, you might be back to ODIS or other. If it wasn't there before it might be something to do with the ODIS but I've no idea about the delay in presenting, computers and computer programming are a mystery to me other than all the errors and omissions, "glitches", patches and updates than solve one thing and create two more - and of course that computers are very dumb and need full, specific, correct instructions to operate at all.
