Coolant issue
What you say is correct, but the service unit claims that everything is ok, the cooling system is tight without leaks, and the losses result from evaporation. In this case, I will send an email to Skoda Europe and Skoda Czech Republic, in which I will explain the situation, and ask for their point of view.
Your service unit is telling you complete nonsense, the cooling system is a sealed system - there should be no evaporation provided the pressure holds and there are no leaks!
Have you tried replacing the pressure cap on the expansion tank?
1 hour ago, Warrior193 said:
Unitatea ta de service îți spune prostii complete, sistemul de răcire este un sistem etanș - nu ar trebui să existe evaporare, cu condiția ca presiunea să se mențină și să nu existe scurgeri!
Ai încercat să schimbi capacul de presiune de la vasul de expansiune?
I understand perfectly what you are saying. Regarding your question, the answer is no.
I'd suggest purchasing a OEM replacement pressure cap to see if that resolves the coolant losses.
