USB port swap instructions needed
Has any one got a video on how to remove the USB port to swap for a carplay one? Or clear instructions how to unclip it? I've got the screen and climate control off but can't figure out the clips holding the port in. Thanks.
Ok got the usb port down in the car. How do you do the clips on here to get it out and replace the old one?
Towards the end of this thread, you will see a photo of the plastic panel where the usb and aux module fit id say you need to remove that plastic panel to give you access to the two lugs in your photo. The one on the left has been damaged a bit but will probably still hold.
I'm not sure of your vehicle ent system spec or age. Is it pre 2016? Or what you're trying to solve exactly. If its new functionality I'd say you will need new coding..
Just trying to update it so I can use android auto etc. All sorted now. Thanks for your help.
  • 5 months later...
Hey Tcuk,
How did you manage to remove the panel that houses the USB and AUX ports.
Can’t see and clips or screw, have no idea where to start with it…
this might help ?
