Škoda Octavia 3 MIB1 MSTD_EU_SK_P3420
hello, I would also like a firmware update to the latest version, I am currently using version 0435
Edited by Bogdan021
i wanted to edit the tags
this is what i have now
I'll bring in @pab567 to assist here.
PM
do i need to extract all of them in to the SD card or? @pab567
1. format SD (best max 32GB) under FAT32
2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder)
3. insert SD card into the slot
4. enter Service Menu (long press MENU button)
i did what u told me and i think it’s doing great
does my navigation support SmartLink and if yes, is there a way to activate it? also the update is done, i really don’t see any difference @pab567
No, it does not support SmartLInk. The update just fixes some bugs, no new features.
alright thanks for the update @pab567 🙏🏻
Could you please send me the newest version for the same navigation like the Bogdan?
Its even on the MIB helper site if you google for it (MSTD_EU_SK_P6230 MU0490) so should be able to d/l from there, I did.
I've been long time getting around to doing it, things getting in the way...wife cancer and due to that I'm doing everything, both her folks died in the last year too, and she burnt out her citigo clutch trying to get to one of them in hospital ( for context had a puncture first though) ...I finished repairing the clutch just earlier this month. Maybe we will catch a break and win the premium bonds soon ?
So I'm gonna be onto this soon hopefully asap.
Also have to replace one of my shocks and take a look at the spring - the other side failed ( prematurely?) common issues on these roads snapped and I had the garage replace that side but might do the other one myself as I got the equivalent Monroe shocker brand new off ebay, IIRC I had it for about £40 or so. Given what happened to the other spring I might need to factor in one of those but no idea what it is, I think sportier OEM one.
Edited by vRSAnt
I used a copy of this MSTD_EU_SK_P6230 MU0490 if anyone else needs, the site I think I had it from was mibsolution.one is currently down though.
I was wary of the copy I had and passage of time, but it worked fine installed, I just have to clear the fault code ( have odbeleven but pro ran out and doesn't cover the adaption by looks of it)
Excuse the state of my interior I don't use the car that much and could use a vaccuum.
So I tried to follow the update procedure exactly , I have an identical radio ,
The installation froze and still reports SWAP error once -1 and once -7 .
The radio can't even be turned off , it just restarts and loads the update again even when there is no SD card .
Can anyone advise ?
Hi all
I'm also looking for this firmware. It's not on mibsolution.one anymore
Any help appreciated
