Whining noise
I get a whinning when I take a right hand bend what is it?
And can I get my Vrs serviced anywhere or does it have to be a dealer to get the service history:confused:
As included in the FAQs section of Skoda UK's website:
Can I go to a non-Skoda retailer for servicing?
You are of course free to choose where you have your vehicle serviced. However, we would always recommend that a Skoda Retailer is used as they receive full training in the servicing of Skoda vehicles and are kept up to date with technical information. Having a service completed at a non-franchised retailer will not in itself invalidate the warranty. However, should any difficulty arise that is deemed to be as a direct result of incorrect/incomplete servicing, any remedial work required would not be covered under your new vehicle warranty.
Is the whining noise present at other times or only when cornering, and at what sort of speed?
Is it high pitched or is it more of a grinding sound?
It's not your wife is it?
It`s more of a grinding noise,and it only happens when goin around to the right hence I think it may be a bearing
Bearing is possible, but there are other causes.
What other things could cause this.Being a bit of a virgin to skoda`s I would normally know the sound of a knacker bearing on another car
Could be wheel bearing but also quite possible is the bearing in the top of the strut, as I had that on mine.
Keep an eye (ear) out for it though to see if it gets any worse, and I'd get it checked :)
Went to the garage Ithey said it could be the drops links so getting them change out have been quoted 33 pounds does that sound about right
Drop links wont cause a whining,more of a knock.
If you getting a whining/groaning from the front on right turns I would think there is an issue with the left front wheel bearing.
It's more of a rubbing noise like rubber against each other:confused:
Found out yesterday that the noise was a build up of corossion on the disc so I need new discs and pad has anyone know of a site I could buy from I have a company here that have quoted me 91 quid for the lot
If it's £91 for two OE quality discs and a set of pads, with wear indicators, for the front, I would say thats a pretty reasonable price if inclusive of VAT.
worked out even better it was only 87 quid:thumbup: how easy is it to fit them ur self
