Is there an option (via a scan tool) to open/close front windows with ignition turned off
My wife's 2015 SE needs the ignition on to operate the front electric windows (rear windows have my preferred crank handles), as a passenger I want to be able to open the window(s) as I really dislike getting into or being in a sun overheated cabin.
Is there a way on this model to set it up on a scanner so I don't have the key in ignition and ignition on?
Thanks in advance.
Edited by Former
typo
  • Former changed the title to Is there an option (via a scan tool) to open/close front windows with ignition turned off
@lewiswal47 I was hoping you might be able to advise me on this(?).
Usually if you keep the unlock button on the fob pressed the windows will open (if you have convenience windows enabled)
You vehicle may be a bit long in the tooth
Edited by Crucian
Thanks for your reply but my wife's car has electric front windows but rear are (my preferred) manual crank handle window winders so I'm not sure it has convenience windows and the remote keyfob may not be in my possession at the time, I'm standing at hot cabin with door open to let some heat out waiting for driver or I'm sitting as a passenger with driver elsewhere.
Take the spare key with you?
Thanks. AG Falco
I don't want the responsibility (or bulk of flipkey remote and metal keys), even if I drive if the car owner is with me the owner takes possession of the keys when out of the ignition and I'm more than happy with that (by choice I would never have a remote).
Leave the car owner behind then. 😉
Thanks. AG Falco
Thanks. AG Falco
But who's going to drive me back then! 😁
Your chauffeur of course.🫡
Thanks. AG Falco
Thanks in advance.
Apologies for the delayed response, I've had a very busy few days.
AFAIK this is not possible. Windows should be powered via Fuse 30 "Power windows, light switches, reverse light switches, control unit for air conditioning system, control unit for park assist, exterior mirror, power feed for center button strip, power feed for side button strip, interior mirror" which is an ACC switched.
Its really annoying, I know. Its especially annoying that models with rear windy windows dont have one push open/close!
Simply clever.
SWMBOs SEL Fabia has similar window setup - AFAIK, there's no convenience opening option.
Thanks for replies both. In one way it's good to know as I thought I was perhaps being a bit slow and/or not seeing what's under my nose or belly.
I would much sooner have the "infinitely variable, Sir" windy windows at the front too and the one-touch bit doesn't bother me but the down-a bit, up-a-bit on the switch to get the window(s) where I want also annoys me, I feel like I've rung The Golden Shot.
Another dream shattered . . . 😄
