AdBlue
Hello!
I have a problem with my skoda superb 2016 2.0 diesel. Yesterday it appeared a new error with adblue ( adblue DEF. no engine start in 1000km). I refilled the adblue tank and drove for 20 minutes, after that it disappeared. Today it appeared again.
First time when it apeared ( yesterday ) it came with the check engine light. Today when it appeared the check engine did not appeared. What should I do now? First things to do? It s the first time when I have a problem with adblue.
How much did you put in? You can overfill these i believe
One of the driver menus (right cog on steering wheel) will show you how much is in there
Also turn your ignition on and don’t start the car for 1minute (manual says this)
Edited by Danoid
After i refiled it showed 13000km range, which is normal for my car.
I'm pretty sure there is something wrong with adblue system itself, not just lack of fluid. It shouldn't say error, let alone give check engine light under normal conditions. Do you have any obd scanner to scan for errors? How much fluid did you refill, i.e. how much fluid was in tank when it showed you error?
I refiled like 4-5 liters and after that it was full. Don t have obd. From yesterday till today i made 100km. Today when i arived home I parked the car and the error appeared
What range does it currently shows? Did you overfill it, i.e. fill it to the brim?
When the error is on the range shows 1000km. But normaly it is 13000 when full. Tomorrow I will refill to see if I can. I fill it until the pistol fired three times.
Overfilling adblue system can cause all sorts of problems and it can cause adblue to misbehave. I personally on my mk3 fl superb, since i have digital cluster and i have reading now much fluid is missing, wait until it shows 10.5-11 liters missing, buy a jug of 10 liters and fill it so i can never overfill it. Since you don't have any diagnostic tool that could give us more insight into problem, I think you need to take it to workshop since check engine light and errors that keep returning clearly shows that something is not right with adblue system. Last thing you need is to get stranded by your own car if it refuses to start due to adblue error.
Today when error appeared the check engine did not appeared
Yeah but it still showed error, where in normal conditions it should just say refill adblue. Besides, you filled it day before and it shows like its empty. My superb have about 13 liters tank and i think so do yours, so for it to show 1000km range or any message regarding fluid level with just 5 liters missing is not normal. What your car is trying to say is that something in your adblue system is broken (pump, sensor, injector, software error or whatever) and it gives you 1000 km range to get it fixed before car shuts itself completely. You have some problem with adblue system which cannot be further diagnosed without some ODB scanner which you don't have. Take it to shop.
Did you try the ignition only on for 1 minute then start car?
I will try
The error on your dashboard is not because of AdBlue Level.
It is a warning that there is another problem with the AdBlue.
The main thing that is monitored is the quality of the AdBlue, it has to have a certain urea concentration otherwise the system will think you have filled it with water or it is contaminated.
You will need to read the DTCs to understand what exact fault you are detecting.
Also note there is a minimum refill amount for AdBlue for the system to release the warning/protection.
If you look at the driving data in the instrument cluster it will tell you distance of AdBlue left plus the min & max refil levels.
You cannot overfill the AdBlue System.
I fill mine at the petrol station from a pump and I stop when it clicks 3 times.
Also, when refilling the AdBlue, it's normal that the warning is not cleared immediately.
It will take some time for the system to detect the new level so either waiting a minute or so at ignition on or driving for a few minutes is needed before the warning will go away.
This is normal.
@Gabbo Surely the AdBlue if not meeting the quality must be HOOKY stuff bought or given to you from a dodgy geezer.
Opened container obtained from somewhere or someone or another...
From a farm or haulage company and not a Trusted Retailer, or Filling Station delivery system.
Edited by Ootohere
I'm not sure of the shelf life of AdBlue once opened but when exposed to air it will dry leaving a crystallized residue.
Assuming that the sensor was working properly a quality error would indicate bad, contaminated or diluted AdBlue.
My point was more that the warning was not related to the level of AdBlue & a check of the DTC is necessary to further understand cause.
After these days i observed that the error appears random and dissapear random without to do something.
That sounds sensor related then to me.
Open the bonnet and look around the coolant reservoir, someone had it on here where it crystallised on a pipe due to a leak
Edited by Danoid
Did this ever get resolved?
I have a similar issue on my 2017 2.0 diesel. Last time it was filled - about 6m ago, it took three journeys to register the fill (and the distance remaining to go up).
After that it put the engine management light on, with a P203 error - "Reductant Level Sensor Circuit Range/Performance". I cleared this code, but it's recurring.
I recently re-filled the adblue, but this time it hasn't recognised the fill at all, so I'm on a countdown.
I've tried some Wynn’s Crystal Clean & Protect in it, but no difference.
I did read that sometimes the car gets confused about where the level really is (it did have a new battery some months back), but needs VCDS to reset this - but I'm thinking it's probably the sensor (= new tank), which will be an expensive job.
Any thoughts or experience? Does anyone near Hereford have a VCDS tool?
When you see the spanner, its a system fault, it will start a count down to non start and when it gets to zero it won't let you start it. So if you are driving and it gets to zero, turn the stop start off, it won't cut out, but if you stall it or turn it off, that is where you will stay until it is reset (with a scan tool) for 30 km more to get you home or the problem is fixed.
Chewed wiring and pipework can cause it, yes the pipe work has a heating element running its length (inside the convoluted pipe) to stop the urea freezing in use.
when the little blighters sink their teeth in the foil it can interrupt the circuit causing the dreaded spanner light to come on.
The in tank heater, pump in the tank or ecu also part of the tank can fail due to moisture ingress as it did on my VW T6.1 van recently requiring anew tank under warranty. Why my next car will be petrol.
This emissions crap is killing our cars while China, India and North Korea press ahead building coal fired power stations. Delusional fools thinking electric cars will save the planet while goodness knows what is being spewed into the atmosphere from the numerous wars around the world.
Edited by 3T51704x4
Typo
Yep, diesels are now less reliable than petrols and cost a fortune to fix. With all the emissions systems either petrol or diesel put out virtually nothing anyway, and the taxes on them are just money making scams, or at best virtue signalling, all the time driving UK economy downhill.
I might sound like a bit of a killjoy, but I'm inclined to agree.. I called it a day with diesels earlier this year as a result of one problem after another.
I've closely watched what was then a 20P per litre gap above Petrol open up to more like 30P in just this year. That gap is manufactured (IMO) and won't be closing at anytime soon.
I've taken my 2016 Greenline from 152,000 miles to 191,000 miles since I bought it in March 2025.
In that time it's been 100% reliable in terms of never breaking down and never going into limp mode. Including when a glow plug failed on a trip to Prague in September 2026. The car drove fine and I replaced the glow plug when I got back to England.
I've topped it up with 10 litres of Adblue plus a bottle of Wynns anti-crystal every 6,000 miles or so.
I've had no Adblue issues. No DPF issues. No EGR issues.
I paid £0 road tax for 2025. And £20 for 2026.
It does 60+ mpg on a long run, driving at the speed limits when safe to do so.
Insurance is below £400 per year for me.
OK, it's a slow grand-dad's car to drive. But 99.99% of the time, the lack of engine power is not an issue on the roads of the UK and Europe. Any time I lose by a lack of rapid acceleration is made up by having to stop for fuel every 700 to 800 miles.
It's not a Skoda, but my van runs adblue. Bought it with 130k on at the start of 2024, not it's on about 170k. I dropped the injector out and cleaned it with warm water when I bought it, even though there was pretty minimal residue in there. At the start of this year, I hadn't used the van for about 3 months and it faulted on the final O2 sensor on the system and started the countdown of doom. After a bit of reading, and nearly falling for it, I found that fake sensors are a thing, so I paid Merc £400-500 for a new one and it's been fine since.
Rightly or not, I don't use anti-crystal, the van uses about 1litre of adblue per 1000 miles. I fill it up at the lorry pump at a garage that sees a lot of HGV's coming through, so my hope is their stock doesn't get chance to get old.
To be fair, adblue systems aren't complex, it's not too dissimilar to an old Single-point fuel injection system when you think about it. When the engine conditions are right, it injects, and monitors the O2 sensors before and after the cat to see if it's worked. Yeah, I'd rather not have it, but it's not the witchcraft everyone makes it out to be.
