Firmware Request MST2_EU_SK_ZR_P0480T
4 minutes ago, Cairus said:
Where did you get the information that there is supposed to be a firmware version 05xx?
Hello, only in the search. I haven't verified it. It should be the 2021 edition. But I'm not really sure.
  • Replies 52
  • Views 7.1k
Hello, mibsolution.one is not working, cannot download FW. Can someone send me the MST2_EU_SK_ZR_P0480T FW to my 2018 Superb?
Can’t access mibsolution, anyone has mirror for P0480T?
  • 4 months later...
On 09/06/2025 at 18:14, pab567 said:
I sent you download link in PM - just pls note that if you are looking for a possibility to run Android Auto or Apple Carplay the this is NOT possible with your unit.
Hey, can you send me the download link aswell please?
sent in PM
Zdravíčko chlapi poslali by jste mi odkaz na MST2_EU_SK_ZR_P0480T
scháním firmware. odkazy nikde nefungujou.
English please
Hi guys, could you please send me a link to MST2_EU_SK_ZR_P0480T? I’m looking for the firmware. The links don’t work anywhere.
On 09/11/2025 at 10:09, pab567 said:
Sent in PM
can i get the MST2_EU_SK_ZR_P0480T too? thx
Hi iam also searching for MST2_EU_SK_ZR_P0480T could you pls send me a link ?
Sent in PM
This is spooky. I too am searching in vain for MST2_EU_SK_ZR_P0480T to replace MST2_EU_SK_ZR_P0472T.
I am a complete novice in matters such as this, but I have managed to format an SD card in readiness but MIBsolutions1 is still down.
Could I please trouble someone for a copy?
Hi, I'm looking for the firmware file MST2_EU_SK_ZR_P0480T so I can update my unit to the latest version. Would really appreciate it if anyone could share a working download link. Thanks!:)
@pab567
Thank you so much PAB567.
I shall take some brave pills, put on my big boy pants and see if I can carry out the update.
Thank you once again.
Good Morning Sir, apologies for reaching out but Google Gemini recommended i contact you in regards to an issue i am having with my Skoda Superb 65 plate.
Yesterday being very very hot (showing as 33c in the car) i used the car in the morning and all was fine, and then when i went to use it in the afternoon i turned the ignition on and found that when i clicked "SmartLink" i am now greeted with the message "You can activate the function by means of an activation key. please contact your dealer" which is very frustrating as i have owned and used the system for the last 6.5 years. I have performed a hard reset on the infotainment system, unpaired my phone ( from my phone itself, as bluetooth has disappeared from my car), also disconnected the black battery cable and left it for 15 minutes, tried the following day when the car was much cooler and still no smartlink. When i checked my Installed SW Train Version it shows as "MH12_ER_SKG11_P2104" and Google says this is very old firmware and could be the cause and advised to reach out to yourself. Are you able to help at all please as my Skoda is my World, it's the best car i have ever owned and im even holding off of buying a new superb as they are not as economical as my 2.0 automatic and the tax is cheaper on mine.
My current software information is:
  • Installed SW Train Version: MHI2_ER_SKG11_P2104
  • Installed SW MU Version: 0318
I’ve read on the forum that this older firmware can suffer stability bugs under heat stress. Would you happen to have the link to the newer firmware update (such as K3343 / MU 1433) that matches my unit so I can attempt a clean software flash via SD card to restore it?
I absolutely adore this car and plan on keeping it for a very long time, so any help or files you could provide to get my system back would be immensely appreciated.
Hello pab567!
Can you provide me also the link to MST2_EU_SK_ZR_P0480T.
Sorry to jump on this thread as well, I'm also looking for MST2_EU_SK_ZR_P0480T please
Current details:
  • Installed SW train version: MST2_EU_SK_ZR_P0472T
  • Installed SW MU version: 0472
  • Part number: 5Q0035874C
  • Software version: H29.319.51_STD2Nav_EU
Thanks for your help!
https://mib.plain.gg/files
That did the trick - thanks @Cairus
Hello,
Iam looking for a download of MST2_EU_SK_ZR_P0480T .
Since new mobile i have issues with Android Auto, maybe an update will fix. Can someone please help?
Best regards
Daniel
