Posted
The airbag light has been on. I have had it diagnosed and it shows a fault with the side airbag sensor. I took off the doorcards and it seems like they do no match in codes. It comes up as short circuit on airbag system and airbag module faulty. I have a feeling the side airbag sensor is from a different fabia and not specifically this one. Anyone have any idea on what to do as the local dealerships are being really unhelpful.
Pls share VIN and scan with errors inidicated.
Hi, welcome.
pab567 given the information may be able to help you a lot, also being friendly, unlike your local Dealership.
Thanks,
the vin is TMBFR6NJ5JZ064228. The errors that come up are B200000, B101713, B103613
Pls share full scan, not just the errors.
I only took pictures of the codes it gave. Sorry
I'm sorry but without full scan, where I can see modules part numbers and errors in each module, I cannot check if they are the same as installed in factory and make troubleshooting.
If you've not already done so you could look those codes up on the internet and see video for general information and possible routes to fixes.
Or depending on how far you want to go yourself have a look at the diagnostic techniques this chap uses, there are plenty of others but to me this chap seems thorough and admits when he makes mistakes and shows real world working. - https://www.youtube.com/@mrautoservices7354
HTH. Good luck.
