Installing piggy back fuse to power a GPS tracker
Looking to install a GPS tracker unit connected to a permanent feed fuse. I will make the connection by selecting an always on fuse to piggyback on (probably fuse 21) . Question is where is the best location from the fusebox to connect the earth? I am driving a RHD version with fusebox behind the glovebox. Any photos to help locate would be super useful - Thanks in advance for any help
I usually either find a bolt in metal under there or drill a little hole and put a ring on the wire and screw it down on that.
