End of my Mk1 @ 480396km thanks to all the great Mk1 contributors was a great run!
End of an era this car (2005 1.9tdi AVF Auto) has been a great servant but couldn't justify the money to keep it going. I replaced the rack earlier in the year as it had leaked at the inner tie rod seals, I think a loose boot on the tie rod allowed water in and the rust did the damage so could potentially have been prevented had I caught it on time. The new rack leaked after a few months and took out the pump so that spelled the end,was a pity becuase otherwise it was running well. Original engine and transmission untouched used no oil between changes normal servicing plus the usual door locks, 1 alternator rebuild, set of front wheel bearings, rear hubs and a tandem pump. Cheap motoring helped by some great knowledge from contributors on here, I got a 2017 2.0tdi DSG to replace it so hopefully it will serve me well.
End of an era indeed. Healthy old mileage too 👍
It’s ten years since I replaced my 2005 Mk1 with an Octavia Mk3.
Hope the new one does you proud.
Gaz
Edited by Gaz
Added a year
