Headlight reflectors
Got 2024 Supurb Technoloy with LED headlights. Wanted to sort position of Eurolite reflectors. Car not listed. Contacted their customer service and the brilliant Julie replied straight away. She asked for some photos and came back with answer same day. Lights same as Karoq, diagram 228.
Thank-you Julie.
Hi there Derek. Not sure what level of tech you have but in my 2024 L&K, there is a facility to adjust the headlamps for continental driving, as well as changing the speedo to kph. I may be mistaken but I thought this was standard across the range. Can you check your infotainment system by going into VEHICLE then HEADLIGHTS. if you have this but are unsure I can post you some screenshots. 😀
Yep, have checked on screen. No option to adjust headlight except for vertical angle (ie for loading). The Combi Technology is the base model so no adjustment. On L and higher, I believe.
Cheers.
It looks like the non adaptive headlights dont need adjustment according to the manual.image.png
