Daytime Driving Light bulb
I need to change the bulb in my Daytime driving light/ side light. Found out it's a sealed unit. Has anybody changed one on a 68 plate Superb .is this a flow in the design. Is it a replacement headlight unit
LEDs?
No...it's like a standard side light bulb. . All the bulbs in the headlight unit can be changed from the back as normal but no access to the daytime driving light.
It's one of the first things I changed when I got the car. I hated how yellow the DRL bulbs were, even compared to the factory H7 bulbs. This excellent post from @SJCSE details the procedure of cutting the unit and once done, the cap fits perfectly:
https://www.briskoda.net/forums/topic/379864-se-and-se-business-drls/#findComment-4456863
I've since gone through various PW24W LED options, but the only ones I found close to the Osram Cool Blue Intense H7 I use (just road legal) kept giving errors. I ended up going with halogen bulbs that are very close and obviously give no errors. It's the blue tint version listed as "white":
https://www.aliexpress.com/item/1005002462773625.html
Working perfectly for 7 years.
EDIT: I remember having to shave a tiny amount off the leg of some bulbs, just to get a perfect fit.
Edited by Alan_P
Thanks for that. I gather all the unit has to come off for me to cut a hole and get the cap from the dealers 👍
It's the wheel lining that needs to dropped down. You could take the headlight unit out, but that's a lot more work and not necessary. Check the post for full details.
Dealers can supply the cap, same as the one just beside it.
