MIB3 starting to repeatedly lose connection
Hi,
MIB3 in a 2021 Superb running v332 firmware. iphone 15 on wireless carplay. The phone always used to wirelessly connect on startup, then disconnect once sometime within the first couple of minutes, then reconnect and be fine for the rest fo the journey no matter how long. Recently, its starting to drop connection and reconnect (sometimes failing to) a few times in succession.
I also had one incident of the GPS being way off and in a different direction. Are these recognisable symptoms of any sort of breakdown of something? OCU starting to fail?
I haven't tried a wired connection but I'll give that a go and see if it makes any difference. On longer journeys I prefer that over cooking the phone on the wireless charging plate anyway but it does feel a step backwards in tech/convenience.
Edited by travs
Correct title and tag
  • travs changed the title to MIB3 starting to repeatedly lose connection
Update on this - plugging it in is absolutely faultless so looking at the wireless carplay aspect.
I can't see any way to roll back to v330 to remove v332 as a variable. Anyone got any thoughts on what might be going wrong?
