Retrofit Virtual Cockpit LHD
So,
Our Octavia 3 will be getting a Virtual Cockpit.
I'd like to document this process a bit here.
What's needed:
Virtual Cockpit ---> Part number 5E0920790A
Bezel ---> Part number 5E0919287 (subject to change)
Additionally, if you want navigation in the VC and other features, you'll need to run a MOST cable from the VC to the 5F module.
I bought a used one myself.
But be aware, the process for adapting the instrument cluster has been made stricter for used units.
You have to submit an application with the data from both the original and the new instrument cluster.
The factory checks if it's stolen, etc.
After hopefully receiving approval, the dealer can program it. Important: Always take all keys with you.
For this conversion, I want to do the instrument cluster myself using an EEPROM dump. I can also do the mileage reading myself. This isn't possible with ODIS on used units.
My only remaining issue is adjusting the CP. I'll have to wait and see if I can find the information in the dump.
I'll let you know as soon as there's any news.
So, it arrived today...
First things first: cleaning it, probably replacing the display, and doing a data dump.
Surely those water spots will clean off?
Looks to be quite cold though.
Well, there are two options:
1) You do it the safe way. Have it installed at the dealership, submit an inquiry, wait, hope for approval, learn how to do it, remove it, and adjust the mileage.
2) You learn as a child never to listen to your parents or anyone else, so you do it yourself and stubbornly insist on your own way, which usually ends badly. (Applying the Seat dump to Skoda is a bad idea.)
I opted for the second option and made things complicated for myself.
Long story short, I ran into a TPI situation, meaning the control unit is fully diagnostic-capable, but the display remains dark. This often affects 2019 model years, specifically the first generation XXX920790 without an index or with index A Virtual Cockpit Generation. So, Immobilizer Generation 5A.
If the software glitched, it can be fixed by flashing the complete firmware.
If the software has glitched, it can be fixed by flashing the entire firmware.
Long story short, I ran into a TPI issue. Then I remembered I bought a defective Kodiaq Virtual Cockpit last year with the same problem...
Okay, Virtual Cockpit can only be flashed with an unlocked immobilizer...
Great, I have two Virtual Cockpits, both with different VINs, of course, and I need an unlocked immobilizer...
What do you do? Right, screw it, get down in the car, remove my own Virtual Cockpit, make a data dump (praying the rosary that the thing stays intact), and flash the dump to both Skoda Virtual Cockpits...
What can I say, it worked perfectly. The immobilizer, CP, key, etc., were all transferred correctly.
Back in the car, connected the defective "Virtual Cockpits," didn't give a damn, turned on the ignition, and started it (note: if a different VIN is detected, the ABS coding is automatically set to 0, and all basic settings of the ABS block are lost).
The car started right up, the coolant temperature and fuel gauges worked immediately, the turn signals worked, etc. That means the immobilizer was completely transferred.
What can I say? It worked perfectly. That means expecting a long flash this weekend.
  • 4 months later...
Hi @Cairus
thanks for this thread. I am in the same situation. I bought a used cluster (5E0920790A) and approached multiple dealerships, but they refused to adapt the cluster.
I recently tried to apply for the permission myself and it got rejected—I think mainly because of the GEKO account used for the application.
I am now planning to try swapping the immobilizer data. I found someone who is willing to help me do this, and I believe he is using VVDI2. Will this work? Can you please share some more info if possible?
Edited by Octavia9099
I don't understand why the dealers are refusing. Yes, the VVDI2 is supposed to work for that. Where are you located? There is a risk that the original instrument cluster could get damaged, though—and then your vehicle would be out of commission.
"Exactly! I really don't understand why they're refusing. I sourced the replacement cluster from a reputable breaker in Australia and even provided the purchase bill with my request. I'm currently located in Perth.
When you mention the risk of the original cluster getting damaged, are you referring to the desoldering process for the chip, or is there another risk I should know about?"
