Tyre Pressure Monitoring fault
So...
...that went well...🙄
Replaced the ABS sensor this morning, and now I've got FOUR warning lights! ABS, ESC, steering and TPMS...
OBDeleven is still saying right hand front ABS sensor.
When I took the old one out, I could see a few fine scratches on the tip, and peering down the hole it came out of, I could see quite a lot of flaky rust, so I scraped that off with a small screwdriver, whilst slowly turning the hub. I also noticed what seemed like a number of small, black plastic "flaps" on the vertical face just outboard of it. No idea what that face is?
Ah! Just looking on YouTube, and what I thought were plastic flaps, are probably actually bits of the magnetic ring on the bearing!
https://www.youtube.com/watch?v=QeILfoNK9q0
(That's a Karoq, but I think it looks very similar to our Kodiaq)!
If you disconnected battery the steering and esc will come on until you turn full left and full right plus a short drive. Looks like you may have to remove bearing and clean or replace.
Alasdair
I've had a rusting bearing wreck an ABS wheel sensor, it was on my 2011 Audi S4, for a few years prior to this failure, I could hear a slight scraping noise, initially only using that car after it had been left unused for a few weeks, then after maybe a mile or so, that noise stopped. Then it never stopped - then when driving it out of the garage to go for its MOT, the ABS etc lights came on, game over!
So, what I discovered is, that all the bigger VW Group cars do not have any protection built in for the, at least, front, ABS sensor from road grit etc - small cars like Polo/Fabia/Ibiza have a plastic shroud to help avoid this to an extent. What does help, I discovered, is that if the wheel bearings "bleed" out a very small amount of the oil in the wheel bearings, hub and bearing inner face rusting is not normally an issue, if the wheel bearings do not "bleed" out any of the oil from the wheel bearing grease, then hub inner face and bearing face rusting can be an issue, especially when combined with only using that car periodically in winter weather.
After getting the ABS sensor replaced by the MOT garage, I removed the new ABS sensor, cleaned its hole in the hub carrier out, then used a piece of dowelling cut at what I thought was a suitable angle and forced that down to contact the inner face of the wheel bearing - then rotated the wheel a few times in both directions, then applied lots of ceramic grease to the ABS sensor and refitted it.
I examined the new ABS only a few days/miles after my MOT garage had replaced it, and it too had started to show signs of scoring - from contacting the rust on the bearing inner surface, so I'd expect that that new ABS sensor would have only lasted a few thousand miles if I had not cleaned up the inner face of the bearing.
Getting access to that inner face to do a proper job on your car will involve removing the drive shaft - if you want to avoid a repeat of this issue.
As said, you need to drive the car to clear the stored faults in some of the controllers even although you have removed the fault and cleared the ABS controller fault code.
Update folks.
It's fixed! There was nothing wrong with my ABS sensor, the problem was indeed the magnetic ring on the inside face of the outer bearing race.
The "bits of plastic" I thought I could see when looking down the hole for the ABS sensor were exactly that. The dark brown curve at the top of the photo is all that remained of a complete ring - basically, a glorified fridge magnet, that just sticks to the inner face of the outer bearing race and rotates with the wheel. Little inclusions within the thickness of the plastic, generate the fluctuating signal for the sensor. It should be a complete circle of brown material and as you can see, half of mine is missing.
I'm now left wondering how far gone the other three are...☹️
Yes, ticking time bombs, they will consume the wheel sensors though while breaking up.
The wheel sensor ring is a series of small magnets, so the sensor reads them as pulses as it is a Hall Effect sensor.
Edit:- I blamed the failure of the RHS front one on my 2011 Audi S4 on the fact that the bearing was not "handing out" any oil/grease to that area so rusting was to blame, in your case it looks like it is a crap bearing manufacture that is to blame as there is very little sign of serious corrosion - and so that maybe bonded on, series of potted magnets, has started to de-bond from the inner face of the bearing and end up lifting up into the path of the stationary ABS sensor "arm".
I'm surprised that a car of this size has just the smaller version of wheel bearing, ie the 3 screw fixing version - maybe that's "progress".
Edited by rum4mo
Dunno? It's only done 72,500 miles and the bearing itself was absolutely fine. No roughness or play. The ring doesn't appear to be bonded to the bearing in any way at all. It's just held there by its own magnetism. I can peel it off and stick it back on anywhere. No evidence of any kind of adhesive behind it? I'm hoping VW have done their sums properly on the three screw fixing. just intuitively, it doesn't look like a bad arrangement. There's a spigot on the bearing housing that locates into the upright. I imagine that and the friction from the tightening torque, will take most of the load, rather than the screws themselves?
I think that the ABS sensor ring will get "stuck" to the inner face of the wheel bearing by some means during the bearing's production - the 2 that I removed were certainly still part of the bearing pack, though after you're finding, I seem to have missed a trick by not seeing just how much effort it would have taken to prise them out - they went to the tip a month ago eventually.
You are correct, the securing ball screws do just that, ie keep it in place - until corrosion takes over and seizes them in place.
How exactly did you manage to get it out of the upright?
I backed the three screws out until they were only in by about 4 or 5 turns and then thumped the head of each screw with a hammer! As the new bearing came with new screws and I wasn't worried about the threads on either the screws or the old bearing, it was fairly easy.
Lucky you, when I removed the bearings from my 2011 Audi S4, I started with air hammering the 4 screws, then clamped the bearing pack with a suitable big 10.9 grade bolt, washers and nut to keep everything together, then used a hub press plate - that worked nicely!
Quite a bit of the aluminium upright in that area was badly corroded and some came out with/on the bearing assembly!
