Kantelen rechter buitenspiegel
Mijn achteruitkijkspiegel rechts kantelt naar boven in paats van naar beneden tijdens inparkeren waar zou dit aan kunnen liggen?
Translated to English…
“My rearview mirror on the right tilts upwards from down while parking what could this be the case?”
@faridjiaw01 - please note that somewhere in the guidelines/rules for these forums is the English should be used. https://www.briskoda.net/forums/guidelines/
OK to answer your question. There is a setting to enable the non-drivers side mirror to tilt when reverse is selected. I assume yours is set to rise upward rather than downward (to, for example, see the kerb line). Take a look in the online manual for how to set it up to behave as you would like it to be.
Edited by SteveTheElder
Does your mirror move in the correct direction when the manual switch is operated?
If not, it is possible that some of the wiring connections have been reversed.
Yes thats ok
41 minutes ago, faridjiaw01 said:
Yes thats ok
Morning,
Please note that English is the primary language to be used in Briskoda.
You can use several translation tools to help with this if needed.
The software can alert the admin team to possible spamming attacks if non English languages are used repeatedly.
Thanks!
If I'm understanding correctly, you may have the setting turned on in the infotainment screen where the mirror tilts down when in reverse to better see kerbs and other obstructions. It will return to normal when a forward gear is selected.
Yes, but my mirror dips upwards
It only dips upwards, probably because you need to configure it to go down. Look for the setting procedure in the manual or online.
AFAIK you have to put the mirror switch to the "R" position, select Reverse on the gearbox, and then adjust from the mirror knob how low you want it to tilt. Did you already go through this process?
If you already did, try doing it again.
I have done that
