help.. octavia
2017 octavia 2.0 tdi . smoke from exhaust, whistling noise from turbo, burning oil. smoke looks whiteish/blueish. turbo pipes all ok. burning alot of oil. no fault codes or eml lights. only light on dash is orange oil can light
Edited by mark8-
more info
Welcome to the forum.
Turbo seals and bearings being 'toast' are most likely reason.
Amber oil light should be telling you that engine oil level is low.
can turbo seals and bearings be repaired or is it new turbo
Beware, engine ingesting significant quantities of lubricating oil via a failing turbo can sometimes cause a diesel engine to run out of control.
Best idea would be to get it properly diagnosed - if failing turbo is the cause (very likely) fitting a rebuilt unit would be my suggestion.
What is the mileage on the Odo?
Edited by Warrior193
question
thanks. car is in garage now to be looked at. they are suggesting could be oil pump or oil pick up starving the turbo?. also suggesting failed regeneration cycle
If the turbo bearings have been starved of lubricating oil, they will almost certainly be shot.
Sump oil pickup or pump issues would also cause oil pressure problems and probable damage to engine bearings.
thanks. im praying its fixable and hope it hasnt damaged engine. car was driving normal , turbo was still kicking in but did have like siren noise when accelerating . just hope its repairable.
mileage is 178000
Recently Browsing 1
