Cleaning Veritate wheels
The Veritate wheels on my Superb have limited access between the spokes, so cleaning the barrel and behind the spokes is a chore but possible with the right selection of brushes and woolies.
BUT ... the numbnuts that designed the wheel added a 'gutter' around the barrel just behind the spokes. It collects a pool of rainwater when parked and is a magnet for brake dust and tar. Getting into the gutter to clean it is almost impossible - I can't even reach it all with my fingertips and a wheel mitt. Lots of chemicals and a pressure rinse helps, but sometimes you also need to agitate the dirt to get it off.
The usual angled wheel brushes and floss/weasels won't get into the gutter, so I'm faced with making some sort of DIY tool to get into the gaps or removing the wheel completely to get at it from behind.
Does anyone have any tips or tool recommendations for how to tackle this?
The same stupid 'gutter' arrangement exists on my Belatrix wheels too. Following with interest!
Toothbrush or small stiff paintbrush, they are a pain to clean !!!
This 'gutter' is also present on my 18" Dofida wheels. I had not realised that this feature was also on other Skoda range wheels.
It drives me absolutely mad!
As Coral-C states it just collects brake dust and road grime in it, then this debris floats to the bottom of the wheel when it rains to form a very visible black stain which then bakes on next time you drive the car in dry conditions.
NOT VERY SKODA SMART.
Completely agree, dreadful design.
Thanks, NascarMike.
A toothbrush wouldn't normally fit into the space and go around the bend behind the spokes. But you started me thinking that maybe I could warm up the plastic handle to soften it, and then bend it to 90°. That might make a workable custom tool. I'll give it a try at the weekend and report back.
I’ve the same issue, to be honest it’s so time consuming that now I try to get the cleaner spray in the “gutter” all the way around, then just pressure wash it out a few times until the water in the bottom is clear.
It so stupid, it must be a strengthening design enabling a light wheel and less materiel = cheaper to build.
"and the winner is" ... NascarMike's toothbrush suggestion. 👏
It's a 'soft cleaning' toothbrush with very gentle bristles, picked up for about £1 from my local supermarket. Warming the handle with a hairdryer or heat gun is enough to soften the plastic so that it can be bent around to the right shape.
I needed to make left- and right-hand versions because there is not enough room to reach across behind the spokes from just one side...Brushes.jpg
Just keep them away from your teeth after use sick
I also picked up a 'turkey baster' to suck most of the water out of the gutter after rinsing the wheels. It's much more efficient that using microfibre towels alone.
Nice one... off to Boots now.
First wash of our car with these Veritate rims. Total nightmare. Spokes are very close together and the gutter around the barrel is almost impossible to clean. My large wheel woolie has enough depth to get into the exposed groove but, as you say, the section around the back of the spokes is very difficult. I will try your toothbrush suggestion.
Otherwise the car is surprisingly easy to clean, albeit huge. Having only been cleaning our SLC200 for six months made me forget how much longer a big car takes to properly clean. Although I probably spent more time on the four wheels than I did on the rest of the car!
I am glad that I won't be running these rims during the winter months. The dwarf 17" Crystal rims have no such gutter or groove, thank goodness!
Best wishes.
Yep !
Pain in the derrière doesn’t come close.
I console myself with the thought that 99.9% of the population will just go ‘ooh, nice clean car ‘ It’s only the saddo’s like us that know ( or notice )
Don’t worry too much, if you’re anything like me, the sleepless nights spent festering over the gunge filled trough behind your wheels will ease after the first six months of ownership.
I have set of 18" wheels for the winter. When they get swapped next month, I'll have the chance to get at the barrels and backs of the Veritates properly. So, fallout decontamination, tar spot removal, and thorough clean. They're already pencilled in with my local bodywork specialist to get ceramic coated after that, which should hopefully make them easier to keep clean going forwards.
@Coral-C I am also thinking the same, maybe professional ceramic coating on these rims would make sense. Your post has tipped me closer to that decision. And yes, once they're off the car, I shall be doing exactly the same decontamination process as you have planned.
Have a lovely Friday.
Monday's little purchase from Tesco. Every little helps! Just need to ask Mrs A for access to her beloved hairdryer, set heat to max and try my hand at the adaptation!
You can use a bowl of hot water as an alternative for softening the plastic if Mrs A won't part with her hairdryer. Soak the brush for a few seconds in the water to warm it.
Once the plastic is warmed by either method, apply firm but even pressure to bend it. You should be able to feel it moving - it's a bit like very thick toffee - and also when it starts to cool and stiffen, and becomes brittle again. You may need two or three goes to get each of the bends fully formed.
I'm looking forward to seeing some photos of the finished product 😄
Much appreciated! I bought the extras expecting to screw up with the first or second attempt.
This kind of thing is quite amusing. You pay a considerable pile of cash for what must be the most software complex car we've ever owned and.....I am buying a pack of three toothbrushes for £3 on my Tesco Clubcard to help clean the intricate wheels!
It could be worse. Our RR Velar cost us £71k back in 2017 and I found myself stuffing pipe insulation to pack out the tension for the driver's window to stop it rattling - one if several DIY fixes. Whether its been the Mercedes, the Volvo x 2 or our earlier Ford Galaxy..... DIY, John Bull solutions have had their place!
I'll post a photo of my remodelling attempt later in the week when I get some time to do this. Thanks again for the suggestion.
Best wishes.
Edited by Arianne
Just picked up a car with these wheels (would have preferred the standard wheels but we weren’t going to say no to the discount. The Karoq that it replaced had a similar trough but also had plastic aero trims which made cleaning the wheels a real pain.
Looks like I am shopping for toothbrushes but one job for later in the week is to take the wheels off and apply some Autoglym alloy wheel protector that I bought three cars ago and never got around to applying.
16 minutes ago, IJWS15 said:
... one job for later in the week is to take the wheels off and apply some Autoglym alloy wheel protector ...
That sounds like an excellent plan. Anything to reduce the build up of brake dust and tar is worth exploring.
When I swap over to winter wheels at the end of this month, I am going to get the Veritate wheels ceramic coated. That won't solve every problem with the design, but it should reduce the elbow grease at each cleaning.
First wash today, good job I am retired and have time.
Tried the bent toothbrushes and the didn’t work that well, ended up pushing a wet lump of paper towel round the channel behind the spokes to get it clean. Best implement remains the long brush from Lakeland (see photo of brush selection). The bent toothbrushes came from Asda, 25p for two.
Read the instructions on the Autoglym can and remembered why I didn’t use it last time - I takes over an hour to cure! They did get treated with the Turtlewax ceramic spray that was used on the rest of the car.
My first wash of the gutter channel on the barrel of the Veritate rims involved a microfibre towel and my little finger! I consoled myself that, given time, practice, ingenuity and this forum, I will find a better and faster method. It will happen!
I can't actually believe I am posting about bent plastic toothbrushes but.....whatever....
I have opted for a 45deg bend to the shaft and it seems okay, as per the photos. I will see how I get on when I do the next wash. Rome wasn't built in a day!
Just be very careful when using any toothbrush on painted car surfaces - my 2011 Audi S4 came to me at just over 2 years old, and slight dark lines at the base of the spokes on its 19" double 7 spoke alloys - that, I think, was caused by "gentle" use of a toothbrush on them to remove brake dust.
@Arianne I went for the 90 degree bend so there was more room for the side-to-side motion. But yours seem to work just as well.
@rum4mo I haven't seen any damage to the surface yet, but point well taken. I opted for a very soft-bristled brush and just use it to agitate the cleaning chemicals rather than scrubbing with it. I had a wheel woolie scratch a previous set of wheels when some microscopic grit got into it, so I'm really careful now.
In any case, how crazy is it that the wheel design is so difficult to clean that we need to debate the details of homemade tools? 🤨
@Coral-C you're right, this thread is almost comical 😅
I am thinking of submitting a patent application for my 45deg toothbrushes. The only thing holding me back is deciding what unique characteristics will support my intellectual property rights!
I'm unsure if 45deg is the right angle but the jug of very hot water can be redeployed to increase the angle further if needed, and I have four other toothbrushes available because Tesco were offering a deal - maybe they have seen a surge in demand from Skoda owners?
@rum4mo makes a good point. The shaft could, over time, impact on the rim even though it is made of plastic. Caution pays, as per the lyrics of Wham (George Michael & Andrew Ridgely).
One last thought: I am glad our driveway is surrounded by a beech hedge because I honestly will feel a complete idiot holding a toothbrush while cleaning my Superb’s rims 🫣. It could be worse: it's not a Jaguar Type 01.
Have a nice weekend.
Well, today was the second wash and a proper one. Plenty of road grime and brake dust from our recent 800 miles round trip to Southern England.
Honestly, while the Veritate 19" rims are elegant, they are amongst the worst wheel design I have ever experienced for cleaning. If not the worst. My toothbrushes, did I just say that, were only marginally helpful. I threw everything at these rims: microfibre cloth, several soft brushes, five different variations of Wheel Woolies and of course the adapted toothbrushes. What a pain these rims are with their intricate design and that evil gutter running around the barrel. It makes me yearn for a 1990s plastic wheel trim which, if scuffed, cost peanuts to replace rather than £90, and a day with the alloy rim repair shop. That's progress!
Thankfully this will be the last time I will need to clean these rims on the car because next Wednesday is Crystal 17" winter rims day. Hurrah. The Veritates will then get one wash and protection before being stored on the rack in our garage until next April.
The car will look dowdy but washing the rims should be easier and that seems like a fair trade!
If anyone has any advice then please speak up. There must be an easier way to wash and clean these rims because I cannot believe owners are prepared to spend so much time as I have today.
Waiting....more in hope than expectation 😥
