My 2017 2.0 diesel Kodiaq 4X4 with manual gearbox has a transmission noise.
My 2017 Kodiaq 4x4 with a manual gearbox has just developed a transmission noise. It happens just after changing up through the higher gears at relatively low speed when I give it some throttle. It can also happen when not changing down in time and giving it some throttle on slight inclines. Sounds similar to brake pads rubbing the front disc after been led up during prolonged wet weather with surface rust on the disc. This sound very much appears to be coming from the gearbox area. I am only the 2nd owner and the car has been maintained by the supplying Skoda dealer up until late 2013 when I purchased with 70000 miles on it. Regular servicing with Haldex oil change at 39683 miles. Cambelt and water pump was changed in October 2022 at 62269 miles. I do have oil and filters changed at 10k intervals along with other routine items. Whether it is a coincidence or not several dash lights have come on in the past week relating to non functioning esp, hill start, start stop and park assistance all not working. I have been to a garage for this and was informed to take it to Skoda to have a 'software update' performed as they could not 'get into the system to check and clear issues'. Is it safe to drive without causing further damage and what is likely the issue (and fix). It has just recently turned 90000 miles. TIA to responses.
Could the noise be from the clutch slipping - does the Tacho rise in sync with the noise?
I assume the 'until late 2013' is a typo and you meant 2023?
Edited by Warrior193
question
OT but the Haldex Servicing is scheduled as @ 30,000 miles / 3 years or sooner.
It was always serviced by main Skoda agent around 30000 up until late 2023. Maybe I should get this Haldex service done now and see if it improves things.
No spike in revs when flooring throttle to induce any possible clutch slip
Have you had the OBD scanned to see if its showing any fault codes???
If you apply the handbrake, select 1st gear, and slowly release the clutch, will the engine rev up or cut out?
Have tested for clutch slip but none evident.
I took the Kodiaq to an independent garage with a very good reputation and was told it needs a software update by main dealer.
I'm finding it a bit of a struggle to understand how a software update can eliminate a transmission noise - has it been explained to you what this noise is?
I stated it may be coincidel, the noise started after I had the dash lights being diagnosed. It was then my garage said it could not lock into my car to pull up outstanding issues.
In an ordinary manual transmission that starts to make a noise during a gear change up or down, I'd suspect the thrust releast bearing being the culprit, especially as the clutch is not slipping and working fine otherwise.
To me, given the description and the errors you quote I think it's not actually a gearbox or clutch issue but actually a brake sensor or hub bearing issue... Especially at that mileage.
Many thanks Skomaz. I have had a possible wheel bearing failure mentioned to me locally. I shall have it checked out before I do anything else. Will post back findings for other forum Kodiaq owners to view.
