Octavia mk2 1.6 fsi starter motor bendix always engaged
Hi all
My Skoda 1.6 fsi 2006 petrol has an issue with the starter motor. It could be mechanical or electrical and I need any advice you can give m.
Today I noticed a horrible grinding noise after start up. After researching the problem I discovered it is the bendix either staying jammed out against the flywheel or not retracting once the car has started.
Does anyone know how to find all the relays?
The only relays found was in the engine bay (no 100)
The Skoda manual only has fuse locations.
Anyone have advice on what else to test as the problem could be electrical.
Many thanks in advance
Edited by raf300
Missed a word
Disconnect thick cable and try to start the engine. You will hear the bendix.
or extend thin cable and ask another person to break connection.
I think its mechanical.
Thanks for replying. Just to clarify
So I disconnect the thick cable from the starter motor and then try to start the engine
If the engine starts and I hear the grinding that means the bendix is stuck out .
Have I understood right?
Happend on an old van of mine. Solanoid stuck and starter stayed engaged. My father was driving and didnt notice. Totaled the starter. If the large cable is disconnected it shouldnt turn over but you should here a click as it engages and disengages. If the small cable is disconnected and it starts then its stuck open. I would remove starter and test on bench. plus check there is no voltage at small cable with ignition off in case its permanently live and the fault is in ignition switch or a short somewhere.
Alasdair
No. Engine will not start but you can estimate healt from klik klik.
Thanks I will give this a go.
Early this morning I managed to find my circuit tester lamp and I checked the 12v plug to see if it goes to 0v once key back in position.
Good news is, I think the electric 12v to the starter motor is working as it should.
So we know the starter motor is not getting 12v continuously
Alasdair
Thanks I just posted above to say I checked and there no continuous 12v being fed to the starter motor once the car is on.
I am just a bit puzzled that a new starter motor (reconditioned Autoelectro ) which was installed 7 months ago has malfunctioned ☹️
New genuine or new aftermarket? Used genuine is better than unknown.
Why starter was replaced? Maybe socket in housing is worn.
In my golf mk2 I had to grease mechanism bc it was lazy. I changed cables aswell to have low resistance possible.
Bendix rozrusznika Octavia
