Codes 00883 and 00668 Octavia 2007
1.9 tdi estate
00883 is I think is an ignition switch problem. it could be the switch behind the barrel that has failed. Read that there is part of the switch that senses when key is in ignition that is prone to failing. It could also be loose bad connection at switch. Check the fuses near battery for corrosion/loosness as well.
Alasdair
Thanks for your input and advise much appreciated
