Karoq gearbox doesn't creep?
There were differences in 2013 as in likely no e-brake or autohold and just a Parking Brake & 'Hill hold assist' or no Hillhold assist. 2 seconds of being held on a slope if the brake pedal is pressed hard enough. The good thing is, what ever you have you can practise with it. What others do is their thing. A Light touch is 'simply clever' but delays need not to happen.
Edited by Evolution13
1 hour ago, thamestrader said:
As I've mentioned previously Ive had 3 DSG cars and I think the key to driving it is acclimatising to the slight delay from when the foot brake is release to when the car just starts to move, only pressing the throttle when it has started to move.
That's exactly what I do.....but, I have auto-hold turned off. Surely if you have it on, the car won't release its brakes and start to move until you touch the accelerator?
I turn it off because my previous TC auto didn't have it so got used to driving without it, and in the Tiguan we had before the Karoq, it released the auto brakes with a bit of "thunk" - it was far nicer to let the car creep before getting on the gas.
@Rory when stopped in traffic queues or traffic lights a light tap on the throttle released the auto hold. Then I read a post, either in this forum or the Facebook Karoq Owners group, where the poster would manually apply the parking brake having come to a halt at traffic lights with autohold. They did this so rear brake lights were then off. The action to pull away is the same simply press the throttle but I think the parking brake releases slightly quicker and smoother than the auto hold release.
Returning to your question about releasing autohold I find the lightest of taps is sufficient to set the car rolling. Maybe it differs slightly between 1.5 and 2.0 TSI engines.
Edited by thamestrader
I would have thought the parking brake would be slower to release than the auto hold ?
The parking brake is a mechanical worm drive whereas the auto-hold just maintains hydraulic pressure in the brake circuit. The parking brake release may appear smoother since there's probably sufficient power in the engine to override it as its releasing.
I’ve started monitoring usage and practicality. @NottsIan your explanation makes sense, I need to work through all the various options, maybe I released parking brake manually - maybe the delay is less with one method.
With auto-hold , the release of the brakes is pretty instant , I would think its just a solenoid holding the brake pressure. The problem may be that it doesnt release until the throttle is applied, but initially when the brake is on, the ECU will prevent any throttle input going to the engine. So if, in the short delay before the brakes come off, the throttle is pushed further, then a larger throttle input is applied when the ECU actually sees the brakes off and causes the perceived possible jerkiness!.
Edited by NottsIan
More details, all very useful thanks @NottsIan. Your last sentence is, I think, the reason for many reported DSG jerkiness issues. Applying too much throttle before the clutches have had a chance to engage, in the extreme severe wheelspin.
Many report jerkiness, often motoring journalists & often those new to a DSG. As it is they are fitted to a big variety of engines, power outputs from 69 bhp to over 300 bhp. Funnily the same vehicle might be jerky off the line with one driver and not with another. Best to comment might be driving instructors that teach in cars with a DSG. There are 3 of these i know on on this forum.
I think I may have cracked it. After observing carefully what I was doing, I have discovered that, on my 2.0 TSI 4x4 with DQ381 wet clutch DSG, Auto Home can be controlled by brake pedal pressure. In a queue of vehicles waiting to get out of a T junction, my Karoq will creep on tickover revs 950 ish, if I very lightly touch the brake pedal it will slow and the green (P) is not illuminated even when the car comes to a halt when I release the brake pedal the car starts creeping again and accelerates when the throttle is pressed. If I press the brake pedal slightly harder the green (P) is illuminated and a tsp on the throttle is needed to release auto hold. This light brake pedal pressure makes switching from R to D when shunting into position much easier too as the car creeps instantly without throttle.
I’m unable to verify what our dry clutch DQ200 Fabia would do as it only has hill hold which may not be the same.
Hope this helps.
I think that is down to driver inputs. The gearbox anticipates and pre selects the next gear going up or down, so if you drive erratically accelerating and braking as the car was expecting the opposite it has to shift from a going up to a going down gear. If you drive smooth it is smooth
Recently Browsing 2
