OEM electric windows + mirrors retrofit on a 2001 Fabia Mk1 Classic – wiring / Comfort module questions
Hi everyone,
I have a 2001 Skoda Fabia Mk1 1.9 SDI Classic with A/C. It is a very basic model, currently equipped with manual front windows and manual mirrors.
I'm looking into retrofitting the OEM electric front windows and electric mirrors using parts from a suitable donor Fabia, preferably an early Mk1 with the same generation of Comfort system as my 2001 car.
So far, my plan is to source from a donor:
  • front left and right electric window regulators + motors
  • the corresponding door control modules (J386/J387, if applicable)
  • front door wiring looms
  • window switches / switch panels
  • electric mirrors
  • mirror adjustment switch
  • the relevant body-side wiring between the A-pillars and the Comfort module
  • the donor's J393 Comfort/Convenience module, if required
I have been studying the wiring diagrams, but I have a few things I would really like to confirm before buying and dismantling a donor.
1. Body-side wiring
This is probably my biggest question.
I understand that the door wiring harness itself is relatively straightforward: the door loom connects through the A-pillar to the vehicle-side wiring.
However, I'm trying to understand what happens on the vehicle side of the A-pillar connector.
Does the wiring from the A-pillar to the J393 form a separate branch of the body/interior harness, or is it integrated into the main dashboard/body wiring harness?
In other words, if I find a suitable donor, can I remove:
J393 → relevant body wiring → left/right A-pillar connectors
without having to remove the entire dashboard wiring harness?
Or are the wires for the electric windows/door modules integrated into a larger common harness with other vehicle systems?
If anyone has pictures of the body-side wiring / A-pillar connectors from a factory electric-window Fabia, that would be extremely helpful.
2. Comfort module
My current understanding is that the early Fabia uses the J393 Comfort module together with the front door control modules.
My current car obviously has a Comfort module already, since it has central locking, but I'm not sure whether the module fitted to a basic Classic is capable of supporting electric windows/mirrors.
Would I need to replace my J393 with the module from the donor?
Or does the existing module already support the necessary functions and only the additional wiring/door modules are missing?
If a replacement J393 is required, are there specific part numbers/revisions I should look for?
3. Electric window system
From the wiring diagrams it looks like the electric window motors are associated with the door control modules, rather than being controlled directly by the J393.
So am I correct in thinking that if I take the complete electric-window hardware from the donor — including the motor/regulator, door control module and door loom — I don't need any additional window controller elsewhere in the car?
4. Electric mirrors
Is the electric mirror adjustment controlled by the relevant door control module, or is there another separate mirror control module?
My assumption at the moment is that I can take the complete electric mirrors, mirror switch and the necessary wiring from the donor and connect them to the appropriate door module/loom.
5. Compatibility / donor year
My car is from 2001, so I understand that there was a change in the Fabia Comfort system around 2004.
I have seen references to the earlier Comfort CAN system and later LIN-based systems.
Therefore, should I specifically look for a pre-08/2004 donor to avoid mixing the two generations?
Would a 2002/2003/early-2004 electric-window Fabia be the safest donor for my 2001 car?
6. Remote central locking
My current key is only a normal mechanical key — I don't have a remote-control key.
If I install a donor J393 that supports remote central locking, would I later be able to have a genuine OEM remote key programmed/adapted to the car?
I'm not particularly interested in the remote key at the moment, but if the correct Comfort module is already being installed, I'd like to retain the possibility of adding it later.
Also, does changing the J393 have any effect on the immobiliser, or are the immobiliser and remote-locking functions separate?
My current idea
My ideal retrofit would basically be:
Donor:
  • J393
  • relevant body-side wiring
  • both front door looms
  • J386/J387
  • electric window regulators + motors
  • window switches
  • electric mirrors
  • mirror switch
Then transfer these to my 2001 Classic and connect everything using the factory connectors/wiring.
I'm hoping this can be done mostly OEM / plug-and-play, rather than running completely new wiring from scratch.
If anyone has actually done this retrofit on a Fabia Mk1 that originally had manual windows, I'd really appreciate hearing exactly what you had to change.
Especially interested in:
  • exact parts required
  • J393 part numbers
  • J386/J387 part numbers
  • wiring diagrams
  • A-pillar/body-side wiring
  • donor year/spec
  • VCDS coding/adaptation
  • anything that turned out to be unexpectedly different between manual and electric-window cars
Thanks in advance! Any information, photos or part numbers would be hugely appreciated.
There's a helpful chap goes by the name of Pete who might know a thing or two about it.
@Breezy_Pete
I haven't had much experience of the earlier, CAN-based set-up, but I can try to help.
Not sure if manual window cars will have the CAN wiring pair going to each car-side A-pillar connector, presence/absence of the pins may be visible by phone camera if not by eye.
I'm on the road today, but may have some time to look at wiring info later, or you could download it yourself from the available list here:
https://www.briskoda.net/forums/files/file/76-mk1-fabia-workshop-manuals/
Door cards are different and manual window winder mounting is as well (different location) so check there are mountings in your door for electric motor etc.
Sons is a mk1 55 plate with electric front windows and central locking. It may be easier/cheaper to swap doors?
Alasdair
Thank you for all the replies! I've seen a post here saying that the "brains" of the remote locking is in the Convenience Control Unit (CCM), and I also get the same result when searching on google. I corresponded all the wires from pictures of the CCM (6q0959 433 E -E is the highest trim level) and the wiring diagram of the Central Locking, and Anti-Theft System. All the wires are "occupied/taken" so all the wires from the picture I identified as part of mentioned systems. Now the questing is, where are the cables for the Remote Locking ? There is supposed to be an Antenna at least, and probably more. I also heard that It might be in the driver door, but at this point I really don't know. If anyone has the diagram for the Remote Locking It would be greatly appreciated! Cheers!
Antenna is within the central convenience module (J393).
The conversion to remote C/L only needs swap of suffix H unit to suffix E, I think, no wiring changes. There's a good how-to thread on clubpolo that I must've linked to on here.
Did you have a look for CAN wires at A-pillar yet?
Oh, really ? That's nice to hear, for once we don't have to overcomplicate things. I was actually looking trough the wiring diagram just now, since my Fabia is a Classic trim level It only has central locking, and therefore there are no components in the door that require the CAN connections (on higher trim level fabias its the orange/green and orange/brown cables in the blue connector at the A pillar if I'm not mistaken), so It obviously isn't there. Now, what I've seen on the wiring diagram is that for example the AC Control Unit (301) is tapped into the CAN lines (A146,A147), and since my car does have AC It therefore must also have the CAN Connections wired into It to a certain extent. The question is whether I'll be able to disconnect the part of the CAN lines going to the doors and plug It into my my car, making it a plug and play, or do I need to cut and reattach ? Also since we got the Remote Locking question out of the picture, does anyone know whether a Skoda Dealer could make a remote key for my lock barrel and with my transponder chip copied on It ? And the last thing I had on my mind is, will a CCM with a suffix E work with my Classic trim level if I switch It out ?
Thanks you in advance for the replies!
Cheers!
Edited by johnnolan
I know there won't be any CAN wiring in your door loom, but it may get as far as the car half of the A-pillar connections, if you're lucky.
That's what I'm suggesting you look for. If it's there, there will be pins in the appropriate spots of the connector, if not there won't be.
All the CAN wiring in the cabin loom will be 'bound into' the loom in the car body, I expect, but there will be splice points, (the A146, A147) where all the 'Convenience CAN' pairs split off to their respective control units (such as A/C). This is likely to be near to the onboard supply control unit (J519) which also houses the CAN gateway, headquarters of the CAN system. That unit is above accelerator pedal on RHD cars.
You will have to run twisted pairs of wires from these points to each car-side A-pillar connector, and fit the appropriate pins, if they aren't already present.
Will be a pain, but those whole connector multi-blocks will come out of the A-pillars outward for access.
Door removal is dead easy and the job will be near-impossible without this, I think.
Pins 3 and 4 of black 6-pin connector at A-pillars is where I'm seeing A146, A147 in circuit diagrams.
Other thing you may have to add is power wiring for windows, pins 1 and 2 of the black 4-way connectors at A-pillars, from fuses and earth points.
Can't you just chop it in for a Fabia that already has all this? They're not exactly scarce.
Recently Browsing 1
