Does My Car Have the Virtual Pedal?
I purchased my Karoq 1.5 DSG SE L at the end of July 2026. The car was pre registered on 31 March 2026 and I believe it was built in January 2026.
Skoda Customer Services tell me it has what they call virtual pedal electric tailgate operation but I'm not at all sure. Easy Open is selected in the settings but I cannot get the tailgate to open using my foot. I have looked underneath the rear bumper for some sort of sensor but can't see anything. I can't get at a January 2026 brochure to check but I can see the virtual pedal is shown in the latest brochure. It could be that Customer Services are quoting from this brochure rather than the January 2026 one.
I don't know if the virtual pedal was specd in the early 2026 brochure, I'm not doing something right or it simply doesn't work. Can anyone throw any light on this and if I'm not doing something right, where am I going wrong? Thanks.
I have virtual pedal on my Karoq - if can take a while to discover the exact movements needed. Firstly you must have the key on you, stand close to the bumper wave your foot underneath and step quickly back. You must step far enough back and if has to a smooth continuous movement with the foot wave under the bumper. It’s a knack, I did succeed a few times. It’s most useful when carrying things with both hands - which is precisely the time it’s hardest to do - standing on one leg stepping back quickly without over balancing dur to the extra weight of what’s being carried.
Edited by thamestrader
There's a setting via the infotainment system which needs to be switched to on. Our car came with it switched off and our salesman told us we didn't have it! Had I not discovered the setting we'd have assumed it wasn't there.
Download the MySkoda app & then download the Digital Certificate. Inspect > Car Details > scroll to bottom. Look for Virtual Pedal. My March 25 built SEL Edition has it & it mostly works. But like most tech, it somehow knows when you need it most & malfunctions then!
The infotainment setting to enable is vaguely called Easy Open, under Vehicle > Settings > Opening & Closing..
Edited by Rbz5416
MY August 2024 reg Karoq has Virtual Pedal. Sometimes works but mostly doesn't. I look damn stupid 'kicking' under the rear bumper when it doesn't work & so rarely bother. The feature seems to be very unreliable judging by many owners experiences.
As previously mentioned the Digital Certificate available via MySkoda provides a very comprehensive spec for your specific car.
Works reliably on mine. The key is to make a smooth slow movement then step back ...
