Considering a Sportline
After 7 years of Octavia VRS DSGs I made a foolish mistake in February and switched to a Golf mk8 1.5 manual.
I've tried to adapt to it but ultimately can't stand the gearbox and having just had two weeks back in an auto hire car on holiday am looking to get back into a DSG and with a bigger boot.
I saw a lovely Karoq Sportline in Nardo Grey whilst I was away and am currently thinking along those lines. I'd be looking at a used car, likely 2022/23.
I will of course have a good read through here, but if you have any standout must haves or avoids to call out, please do so.
I want a bigger boot than the Golf (521L vs 381L ), DSG and the ability to add a towbar bike mount - the Octavia's were a bit fussy on this, is the towbar an easy retrofit on the Karoq if need be?
Pan roofs look nice, but I seem to remember reports of other VAG ones squeaking, creaking and leaking?
The Golf's tech is punching above it's weight, it regularly warns me of imaginary lane creep and collisions, plus the whole system crashes from time to time, needing a restart to clear - My Octavia's were much better, any points of note with the Karoq?
As I say, I will have a good look around on here, but would really appreciate early warning of any showstoppers, highlights or other thoughts.
Edited by dan245
typo
Having owned two Sportlines and driven a few others, I take the view that the two best options are:
- Dynamic Chassis Control. It makes a real contribution to taming the appalling road surfaces that are so common now;
- LED matrix headlights. Magical technology at its best. All headlights should be like this and one day maybe they all will be.
One of the biggest disadvantages in the Sportline is the ridiculous 40 profile tyres fitted to the 19" wheels. The wheels are also 8J rather than the 7J in the rest of the range, so the standard 215 tyres give little protection to the rims over potholes & when parking. I have a SEL Edition that came with 18/50 & I dropped those to 17/55.
You're already aware of the issues with the sunroof & while the dancing headlights sound great, it's something else to go wrong as the car ages. We're already seeing instances of LED indicator failures requiring a whole headlight replacement at over £1k.
If boot space is a premium requirement, maybe look at an SEL with Varioflex seats. They can be flipped forward or removed completely. Skoda dropped them as standard but I can't remember when.
Whatever you go for, buying from an authorised dealer seems essential for the warranty, as does extending it as soon as it expires. Door locks, shock absorbers, electric boot struts & software issues all seem common.
Edited by Rbz5416
Hi @dan245
I had a Octavia vRS CR DSG for 13 years. Loved the car and covered 139k mostly trouble free miles in it.
April '25 I changed it for a '23 (73 plate) Karoq 2.0 tsi Sport line.
I also tow a caravan with both.
What I liked about the Octavia:
Looks good 😊
Fuel consumption. Solo 50+, towing 30
Boot size
Comfortable seats
How does the Karoq compare:
It's a mid sized SUV, personally I prefer the look of the Octavia hatch
Fuel consumption whilst not as good solo it's only 1 or 2 mpg less when towing. The cheaper unleaded offsets this.
The boot on the Karoq is easier to load (I have a spare wheel so a false floor) but it is smaller than the Octavia.
Seats are more comfortable than the Octavia
The ride I find is similar between the two although I don't have DCC. Even with the 45 profile tyres it's ok.
As for towing, it's so much better.
I had a tow trust detachable tow bar fitted along with the dedicated electrics by a local mobile fitter. Works as it should. Just check the vin to make sure it can be coded.
Agree about the matrix headlights. Never been flashed but try not to think about replacing.
Hope this helps
I think a test drive in both SEL and Sportline models is a good idea. Personally I found the ride quality on the SEL variant better than the Sportline so opted for that when I changed my car.
Google tells me it was dropped as standard on MY24 cars, where it became a circa £900 option. So if it's something you want, carefully check the spec of late '23 cars when the change would have been made.
Thanks all for the REALLY helpful insight.
I think I can live with the 19" wheels as I had them on the mk4 VRS (without DCC) - but will be sure to really concentrate on ride quality during test drives.
I might consider the SEL but the Sportline was the one that caught my eye and coming from a largely VRS and GTi background, I suspect it'll win through for me, even over comfort.
I'll definitely buy approved used and look to use the all-in-one followup cover during my ownership, so hopefully things like headlights and boot struts aren't much of a concern.
Is the pano roof standard on later models? basically I'll happily avoid it if I can.
4x4 Sportlines have 45 profile tyres on 29 inch rims and multilink rear suspension (similar if not identical to Passat, Golf and others) 2wd have torsion beam axle - this is a big factor in ride comfort. Try and get a late 73 plate which will still have warranty and then purchase All-in-one plan. I m just about to do that for my Karoq 2.0 TSI 4x4 Sportline. Cost is £959, cost of 2 yrs extended warranty is £624 - thus allinone 2 services and 2 mots is £335, so that’s £168 per service and mot- 2 years roadside is also included - no brainer. Can get extra 4 years warranty, I have checked DSG, infotainment screen, dash screen and matrix headlight units are all covered if they fail.
@thamestrader , get in there quick and change the "29 inch rims".
@rum4mo oops thanks but I was too late - yes 19 inch rims.
