How Do I Stop the Sat Nav?
I am just about getting to know how to delete previous Sat Nav destinations. But sometimes, the Sat Nav thinks I want to go to the destination when I touch it to delete it and it starts up again. I can't seem to find a way to tell it to stop so that I can try to delete it again without switching the whole thing off, waiting for 20 minutes than trying again. Is there a simple way to tell it to stop and that I don't want to go to the destination again? Thanks.
When following a route, even if by mistake, top left corner is a stop button, it becomes visible when your hand hovers over the screen. If you want to delete a destination: touch and drag left (I think) and a red delete button becomes visible. You can also “escape” from a route by pressing the Nav button.
The touch and swipe never worked for me.
What did work I posted previously back in 2025
Good Luck
tom
Sanqhar
9 March, 2025
I have done it after touching (not swiping) the '>' to the right of the destination name. Most of the time this brings up a menu that includes an 'Edit' option. Touch 'Edit' and the 'Delete' option appears.
I say "most of the time" because sometimes it does not seem to work. I have not yet worked out why.
Not a swipe anywhere.
It was in an older version of the Owners Manual P186
"Delete destination
▶ In the Navigation main menu, tap the function surface  → Destinations.
▶ Tap the functional surface  and select the desired list of destinations.
▶ Show the destination details by tapping on the function surface  at the de- sired destination.
▶ Tap the function surface Edit .
▶ Tap the function surface Delete and confirm the deletion.
I had misread the significance of '>' in the third bullet point. Sorry the cut and paste seems to have blocked this out
