Car juddering during acceleration
I have a 2012 skoda superb 2.0l tdi DSG.
The issue is when accelerating I get a judder around 1600rpm. It is nearly like I am hitting the rev limiter, the revs will bounce and struggle to rise and you can feel a judder through the whole car.
You notice most in 3rd or 4th but it does happen in all gears.
It goes away after driving for a while, not just enough to get engine warm but 20-30 minutes. And strangely after problem goes away like that the next day the problem still won't be there but will come back after a few short journeys.
I plugged in a obd and no faults showing.
I did try record live data and use chat gpt a bit but I'm not convinced by it, at one point it referred to car as a BMW.
Some things that came from live data
Fuel pressure specified and actual seemed to track well
EGR similar
Air mass seemed to have a difference in specified vs actual, and charge air pressure also had a difference.
I took it to a mechanic who thinks it's a gearbox issue, and advised taking it to a gearbox specialist, he kind of said the turbo could be showing issues because the engine management is seeing issues with gearbox and so pulls back on the turbo.
I'm not so sure because of charge readings but looking for any advice from people on here.
Any better ways to confirm issue?
Recently Browsing 1
