Skoda Fabia Monte Carlo 1.2 TSI CBZB - Alternator belt tensioner replacement and Water pump recommendations
Hi all, I'm a long-time lurker and I'm hoping to find out how often the tensioner pulley for the V Belt should be replaced?
I've ordered the parts for the timing chain Kit B replacement (the car has survived to 165 000 kms on its original, but it sounds like a tractor on startup)! Since ordering these, the water pump has developed a leak, and I thought I'd have the timing chain, v belt, and v belt tensioner all done as well.
Also, any recommendations for a water pump? Likely I'll order genuine as it looks like the current one fitted is aftermarket and has only just made it to 5 years of service.
Regarding the V belt tensioner, am I required to replace the entire assembly (part number 03C145299Q), or just the pulley (part number 03F145276)? If I replace the entire assembly, likely Ill order an SKF one.
Thanks.
Edited by VNZ00
Go for ContiTech; it is the manufacturer for original VAG parts. I replaced the auxiliary belt tensioner at 152,184 km around the end of 2024 because there was a little squealing sound in the freezing winter on cold starts. However, the belt from 2013 (original equipment produced by Continental) was still in perfect condition without any cracks or wear. I replaced it anyway just because it came in the kit. For the water pump, go for ContiTech as well I've just replaced a Fiat water pump with that brand, and it is not giving me any problems.
my advice for the timing chain is to buy an original one it isn't very expensive and is a good quality item
Edited by Jack25
Hi Jack, thanks for your feedback. I think in one way or another, the OEM kits have a cross over between the belt, tensioner and water pump, from what I have read (i.e. they may produce one but source the other parts from other OEM's). I don't think you can go too far wrong with any of the main OEM's and SKF, ContiTech, INA all produce kits for all related parts, either with or without the water pump. I was strongly considering buying a genuine water pump with one of the tensioner/belt kits.
I don't know what normally fails on the water pump, whether it is the seal or the bearings. SKF have a good rep for their bearings. There seems to be a lot of emphasis placed on plastic vs metal impellers but do these fail?
In the end, I went with the full kit from INA: INA Water Pump + V-ribbed Belt Kit 529 0534 30
I couldn't find out who the OEM is for the genuine pump for the 1.2TSI as mine was replaced with aftermarket five years ago (maybe someone here knows for sure?). But I would pick the kit in future with the best quality water pump, as it will likely fail sooner than the other parts in the kit, if it is a quality kit. Hopefully I'll still have the Monte in service in five years' time to see if I chose wisely ;)
Yes, the Kit B for the cam chain kit will be genuine. I've heard nothing but good things from the forums once fitted.
Some photos of a genuine water pump, not sure if they help. Plastic impeller. Possibly from 2010 (410)?
Recently Browsing 1
