Skoda Superb Combi 3V539Z suspencion
Hi ya all..
I have a Skoda Superb 2023 3V539Z and it is an Ambition, witch has a softer suspention than Style. I want to make it more sutable for heavier loading, used as a taxi (best car for that use) and being able to withhold pushup traler to be attachet to the towbar without beeing at safety point in maximising the travel of suspention. What can I do to make it more sutable for that kind of abusement?
1 hour ago, Flosi said:
...I have a Skoda Superb 2023 3V539Z and it is an Ambition, witch has a softer suspention than Style. I want to make it more suitable for heavier loading, used as a taxi (best car for that use) and being able to withhold pushup trailer to be attached to the towbar without being at safety point in maximising the travel of suspension...
If it's a FWD (and not a 4x4) with standard ride height (and not lowered ride height, ie. sports suspension) then it might have 3Q0511115AK rear springs.
You can find out what rear springs the car has by creating an account on "skoda parts com" and adding it to the online garage using the car's VIN number. Then when you search for rear springs, only the correct ones are shown.
If it does have 3Q0511115AK rear springs, then a good option to enable the car to support more weight is to go up two in the hierarchy, so that the rear springs are about 10% stiffer than standard.
Two up in the hierarchy from 3Q0511115AK is 3Q0511115M.
Sachs 994977 rear springs (matches 3Q0511115AK)
Length 364mm
Wire diameter 12.25mm
Number of coil turns about 8.0
Sachs 992238 rear springs (matches 3Q0511115M) (about £40 each on ebay)
Length 360mm
Wire diameter 12.75mm
https://www.ebay.co.uk/itm/396331960318
Hierarchy of rear springs (Superb MK3) (1JA=Standard ride height)
3Q0511115AH (1JA+0YA)
3Q0511115AJ (1JA+0YB)
3Q0511115AK (1JA+0YC)
3Q0511115AL (1JA+0YD)
3Q0511115M (1JA+0YE)
3Q0511115N (1JA+0YF)
3Q0511115P (1JA+0YG)
3Q0511115Q (1JA+0YH)
3Q0511115R (1JA+0YJ)
3Q0511115BC (1JA+0YK)
VW Codes Decoder
https://igorweb.org/equidec.aspx
Skoda parts catalogs
lllparts.co.uk/catalogs
Edited by Carlston
50 minutes ago, Flosi said:
Hi ya all..
Length 364mm
Length 360mm
Hierarchy of rear springs (Superb MK3 FWD)
Hi Carlston, it is a 4X4.
C
I cant register to skodaparts.com since I cant get my country code in phone number, can you send me pm so I can provide more info to help me out?
In the Skoda parts catalogue, the Superb MK3 estate 4x4 (standard ride height) has the same ten rear springs listed as the Superb MK3 estate FWD (Front Wheel Drive) (standard ride height).
The only difference is that the Superb MK3 estate 4x4 (with standard ride height) will have slightly stiffer rear springs as standard compared to the Superb MK3 estate FWD.
So probably around 3Q0511115M rather than 3Q0511115AK.
Two up in the hierarchy from 3Q0511115M is 3Q0511115P.
Sachs 992379 rear springs (matches 3Q0511115P)
Length 361mm
Wire diameter 13.5mm
Kilen and Lesjofors make a spring that is sold to replace both 3Q0511115N and 3Q0511115P, but should match 3Q0511115P as this is the stiffer spring of the two.
Lesjofors 4295137 rear spring (sold to replace 3Q0511115N and 3Q0511115P, so probably a 3Q0511115P rear spring) (same as Kilen 65127)
https://www.autodoc.co.uk/car-parts/oem/3q0511115p
There's a seller on ebay that can supply the car's build codes for 3 Euros (about £2.50). If the car has build codes 1JA and 0YE the rear springs have OEM part number 3Q0511115M.
Search "skoda vin decoder" to find the listing.
https://www.ebay.co.uk/itm/226517872578
Edited by Carlston
Is it possible to replace coils (front/back) to give it more lift (ground clerance)
My car has:
0YE/1JA coils ends with M (level 5) for rear and
weight category front L08
It is 4x4, diesel.
3q051115aAT
5q0411105HS
are the coils for Superb Alltrack, is it possible to swap the coils and schokbsorbers to make some elevation and stiffer suspencion?
Some owners who have a Superb MK3 with increased ride height have complained about poor handling.
I suggest you first try 3Q0511115P rear springs, such as Eibach R21706.
The 3Q0511115P rear spring should lift the rear of the unladen car up a little bit, but won't sag anywhere near as much when weight is added to the rear of the car...such as rear passenger and/or their luggage.
Compared to the 3Q0511115P rear spring, the 3Q0511115AS rear spring should lift the rear of the car up by 10mm....whether unladen or with weight in the rear of the car.
To make sure the ride is still comfortable when there's not much weight in the car, it's better to use 16" or 17" wheels, rather than the harder riding 18" or 19" wheels. My preference would be 215/60R16 6.5Jx16 ET41 or 215/55R17 6.5Jx17 ET41. The 215/55R17 6.5Jx17 ET41 is actually a winter tyre option suitable for snow chains, but it will ride slightly better on these 0.5" narrower 6.5J rims compared to the more usual 7Jx17 ET40 rims on the Superb MK3.
The rear of the car will probably look too high if 3Q0511115AS increased ride height rear springs are used without also fitting increased ride height front springs.
Eibach R21706 rear springs (matches 3Q0511115P) (standard ride height)
Length 357mm
Number of coil turns 8.3
https://www.autodoc.co.uk/car-parts/oem/3q0511115p?supplier%5B%5D=112
Eibach R22930 rear springs (matches 3Q0511115AS) (increased ride height)
Length 367mm
https://www.autodoc.co.uk/car-parts/oem/3q0511115as?supplier%5B%5D=112
Edited by Carlston
I have plans to change boath front and rear. If I take the rear coils from M to P (up 2 levels) would it be the same in front?
I have plans to change both front and rear. If I take the rear coils from M to P (up 2 levels) would it be the same in front?
The front springs shouldn't need changing because when rear passengers and/or their luggage is added, most of this extra weight is supported by the rear springs.
Edited by Carlston
On 09/10/2026 at 19:32, Carlston said:
I want to lift the car a little, have plan to add extra lift between springs, also stiff the rear to being able to load more. Here we need the road clearance do to snow in winter time, I'm not thinking too much on handeling, where we dont have any autobahns, ( 90 km max speed limit). As the car is now, the top of all wheels in are leaning towards each other, I belive the springs are not in good shape.
I'm also wondering, Bilstein B4 and B6, witch one?
Length 357mm
Length 367mm
Edited by Flosi
One way to lift the car is to fit tyres with slightly more sidewall height than standard. such as 215/65R16 6.5Jx16 ET41, 215/60R17 6.5Jx17 ET41, 225/55R17 7Jx17 ET40.
Outside diameter of tyres
215/60R16 664.4mm
215/55R17 668.3mm
225/55R17 679.3mm
215/65R16 685.9mm
215/60R17 689.8mm
Edited by Carlston
I’m not going to change tyre size, has 17” rims, just get more ground clearance and better loading capabilities.
For the Superb MK3 4x4 with increased ride height and without DCC (electronic damping control), one option for shock absorbers is Bilstein B6 from the VW Passat B8 Alltrack.
One owner who went with this option said that the damping is similar to standard. If true, then this option could be a way to get very good quality shock absorbers for increased ride height but without the sports damping (which you may not want).
Bilstein B6 and Bilstein B8 have a mono-tube design which is better than the standard twin-tube design. Mono-tube is more expensive to manufacturer than twin-tube, hence most shock absorbers aren't mono-tube.
Recently Browsing 1
