Matrix headlights with auto high beam
I don’t know if I am being stupid and missing something, but I don’t seem to be able to turn off the auto high beam once I have turned it on without flash banging other drivers.
From what I can tell once the car is started and you turn on the auto high beam by pushing the stalk forward, there is no way to turn it off again without flashing the main beam, if you push the stalk forward it turns on the normal high beam, if you pull back on the stalk to flashes the high beam.
Am I doing something wrong?
Pull it back white its actually on high beam.
Yes, what you say, @Neily03 is the only way.
If you enter a lit area whilst on auto (so it becomes dipped all the time) there's no way to take it out of auto until you stop.
Even pulling the stalk back - giving other road users a flash in the process- doesn't reset it. It stays on auto until you switch off the engine.
The issue I have is that I turn it on at the start of the journey, but then go on a motorway and it can get confused by the centre railing and blind the cars coming the other way, if I pull it back on the stalk it will blind the cars in front.
Or I'm on a dark road with no lighting, and following another car, so it is lighting up the path full beam but there are people walking on it, the car will not dip the lights for the walkers, so I don't seem to have an option to put it to low beam other then blinding the car in front .
If the high beam is activated, pulling on the stalk (like you would pull on it to manually flash, not toggle) should deactivate it (so disabling manual toggle or automatic highbeam).
I had the same thing yesterday, decided to try the auto function and then couldn't remember how to turn it off. As others have mentioned I needed to wait until it auto-activated, and then pull on the stalk - that turns it off. Otherwise you're just toggling between manual high-beam and auto "matrix mode"
Do you have your headlights on "Auto"? If so, i think you can press the "Low beam" button, which will turn off the high beam without flashing other drivers
Yes, on my '21 vRS I have the lights on Auto (on the lower switch), and it's just a matter of pulling back on the headlight stalk/switch to return them to normal operation
