Amp wiring!
How do I get the power wires from the bat to the AMP? In my pug and over cars there was a channel between the wing and door and a hole to pass the wires through! I cant see anything simualr on my estate?
Any ideas on getting it in?
you might be able to squeeze the power cable through the hole where the clutch cable goes through
I had to put my cable through and alongside the drivers side of the car up and under the dash , took off speed dials casing and tere should be a romet to put it through there. just be careful the speedo cable is back on firmly when replacing the casing, its a real pain otherwise!
ther eshould b a hole up in the front of hte car that goes in to hte dash board, look under the hood mate near hte battery.
Theres two or three rubber grommet type things between the engine bay and the cockpit through which your normal wiring runs, its a bit of hard work but you can squeeze additional cables through there. The grommets are located in the vertical panel under the windscreen under the bonnet.
It might help to tape the new wire you want to add into the grommet to the ones that are passing through then pull the wiring from the other side , you only need ot move the old stuff an inch or so to get the new wire through to the other side you can then untape it and pull it through and push the old wiring back to its original position.
Once you're in the cockpit run aloing the underside of the dash downthe side panels in the footwells then under the sill covers to the back seats then round into the boot.
Done it! fed it between the wing on the left side by the bat, behind the door hinges and then into the car. under the plastic trim to the back of the car!
Now, just need to stick the amps, sub and parcel shelf with the speakers back in!
