Fairy liquid to cure clutch slip
Been reading this thread after doing a search. Very interesting.
Just where is the inspection hole on a Fabia Vrs? I've looked under the bonnet but cannot seem to find it.
Think I have a bit of a judder/slip on my clutch so I was going to try it to see if it cured it.
Car doesn't seem to run as freely as it did before it had its EGR valve replaced.
Thanks in advance.
the inspection port on gearboxes are underneath you should be able to see the teeth of the flywheel
The inspection hole is actually at the very top of the gearbox under the coolant pipe on the side of the head. It is used to find TDC when doing engine work.
ok me wrong thinking of beamers
:iagree: it's on the bottom on the peugeots too
Wont the saltiness cause problems?
Chris
Thanks everyone for your replies.
I will have another look tonight.
Car currently has a fault on the drivers side electric window switch so its dealer time again. If its not one thing its another!!!
