Oil problem 1.9d felicia
My Felicia 1.9d 1999 spending more oil that i think it need to spend. every 5000km almost 1 liter of oil is spent.
What i seen today in one place of machine there is oil but there cant be. The place of oil is where is air filter and air part of machine there is one plastic in center of machine inside that plastic is oil not so much but it has oil from that plastic is connected to air filter..
I will see this days to make photos so you can see more.. i drive fast 150km/h on about 3500rpg that is not so good for machine maybe because that happened this oil problem in that plastic part of machine.
:rofl:
150/155kmh is the max speed for the diesel. also 3500rpm seems high? I get to about 150kmh and still at 3000ish.
Perhaps the oil is being sprayed up the engine from the timing belt? have you removed the cover to ensure the belt is oil free?
I will try now with photos exsplane what happening because i m bad with English :)
13578.attach
On this photo 1 there is problem under that plastic there is oil.
So what you think why is that? About 1 liter of oil spending in 6000km..
Now one man say me that is hot oil perspire.. and he suggest to close this part of machine
13579.attach
Look photo 2 there is small intestine that coming to that part. Man say me to close that intestine?!? so oil don't go up in that part on photo1.
So please if someone know what is problem or suggest ??
also this man on forum say timing belt ?! is timing belt in connection with this problem?..:confused:
nobody have idea what is problem ?:confused:
