injector question?
does anyone know the following?
what is the cc of std vRS injectors?
what is the cc are TT225 injectors?
1.8T 150HP AGU
06A906031
0 280 150 464
289ccm@3bar
334ccm@4bar
1.8T 150,180HP
06A906031BA
0 280 156 061
321ccm@3bar
371ccm@4bar
1.8T 210,225HP
06A906031BC
0 280 155 892
395ccm@3bar
456ccm@4bar
Audi RS2 316HP
034906031F
0 280 150 984
386ccm@3bar
446ccm@4bar
Audi S6 230HP
034906031B
0 280 150 951
301ccm@3bar
348ccm@4bar
Also here there is a lot of info:
http://clam.rutgers.edu/~dreadsct/resell/1.8T_injectors.htm
thanks that perfect!
anyone know where to get tt 225 injectors cheap?
From under the bonnet of a 225TT while the owner isn't looking? :D
Indeed.
Tools required - screwdriver, 5mm allen key, crowbar or rock (optional)
Time required - 3 minutes (may be longer if crowbar used)
Procedure:
If bonnet closed, try driver's door. If unlocked, open and pop bonnet. If locked, lob rock through window first
Open bonnet, prop open.
Remove engine cover (4 plastic turnbuttons)
Remove two allen screws holding down fuel rail.
If feeling prissy, disconnect 3 multiplugs connecting injector wiring to engine.
Disconnect connectors from injectors.
Lift out fuel rail complete with injectors.
Remove injectors from fuel rail by detaching spring clips and pulling.
Make a sharp exit, stage left...
Indeed.
Tools required - screwdriver' date=' 5mm allen key, crowbar or rock (optional)
Procedure:
Make a sharp exit, stage left...[/quote']
i know how to remove the injectors.. might just go the whole hog and get cossie green ones...:D
but will they fit?
Get greys
Or some Bosch 150351.
560 @2.7 bar through to 680 @4 bar.
:D
they are std bosch injectors... so green or grey will fit...
im just unsure as to how well the ecu will cope with the change? assume combo of lambda and knock sensors should compensate for extra flow?
Listening attentively - go on, chaps ....
only asking cos im curious?
cheers for the pm jon.....
Paul you have a PM :D
Lets see if I can remember this right:
Fuel flow requirement:
bhp x 5.6 (its a turbo)
4 (no of cylinders)
so thats (350 x 5.6)/4 => 1960/4 = 490cc
Assume you don't want to run more than 80% of the max flow of the injectors, so;
(490x100)/(1x80) => 4900/80 = 612.5cc
Hmm, look, my original injector suggestion looks about right :D
Oh and don't forget your fuel pump. Not sure what the flow capacity on the standard one is, I'm sure someone will.
To calc capacity required:
HP x 7.3 (it's a turbo, if N/A multiplier is 6)
Lets say 350 hp, so need to flow 2.555 litres per minute
increase figure by 10-15% if running 3 bar FPR
increase figure by 10-15% if going from 3 to 4 bar.
Enjoy!
Only listening cos I'm thinking of something similar after all the problems I've had with my injectors. I did hear from another poster that he had tried larger capacity injectors and removed them because they didn't give the required results ...
If you want to revise your FPR, you can do that and it'll give different figures for the injectors:
Revised flow of injectors = static flow (thats the one above ie 612) x square root of revised pressure/original pressure eg going from 3 bar to 4
RF = 612.5 x square root (4/3) => 612.5 x 1.154 = 706.8cc
:D
4 (no of cylinders)
so thats (400 x 5.6)/4 => 2240/4 = 560cc
(560x100)/(1x80) => 56000/80 = 700cc
Hmm, look, your original injector suggestion looks abit gay :gay:
700cc injectors.. or go for a RS 500 coswoth style 8 injector setup?
4 (no of cylinders)
Assume you don't want to run more than 80% of the max flow of the injectors' date=' so;
Enjoy![/quote']
So in one formula it's 5.6 and then suddenly it's 7.3 - is that the 80% coming into effect?
Surely the standard FPR is 3 bar anyway?
yes its 3bar as standard... and a common mod is to swap for a 4bar... so does this mean the ecu can cope with an injector swap? as the flow rate would be altered by this?
Me has wondered this too :D Should ask Jabba I suppose ... I know SkodiRS was thinking about this too .... Adrian ???
its all hypothetical of course......
Nick, the first is for injector sizing, the second is for fuel pump sizing.
For injectors there are 2 multipliers, 5.6 for turbos, can't remember for n/a
For fuel pumps, again there are 2 multipliers; 6 for n/a and 7.3 for turbo engines
Standard FPR is indeed 3, but with software it can be taken to 4. Above 4 you need to change the FPR itself. You shouldn't run more than a 5 bar (although you can get them) as it doesn't give as good controll of fuel flow through the injectors, the lower pressure ones give better granularity of flow control.
Paul, the ones I suggested on a 4 bar FPr will flow 682 at 4 bar, close enough me thinks :P
I seem to remember Adrian had concerns that the standard pump was not coping even with a "normal" remap.
D'oh! Sorry :o
an RS4 fuel pump may be the answer... i got detonation on a low tank the other night.. kept full since and no detting....:D
Yup, and IIRC a RS4 fuel pump fits straight in :D
so where is the pump?
