Maximum distance between variable services almost exceeded!
I have an Octavia TDi 110 on variable servicing. The maximum interval between services is 50,000 km which is 31,250 miles.
I had the car serviced at 109,242 and now it reads 139,342, which is a difference of 30,100 miles - and the 1000-mile left light still hasn't come on!
I'm having it serviced on Tuesday anyway. I'll get them to read the service indicators and see what's going on. Either a) I drive like a saint :rofl: or B) it's broken...
J
I'm in a similar position with my Mk1 vRS. I've done 16,000 miles and don't consider myself to drive like a saint either, but the service light still is nowhere to be seen.:confused:
Plus the original Continental tyres are looking good, so I'll have to change my driving style I think, or I run the risk of looking like a bit of a girl.:o
Skinnyman, you still have a theoretical 2,600 miles to go maximum.
Mk1 Octy vRS here, on variable servicing, done 7000 miles since I bought it (now on 35000) and the light has come on. I don't drive it too hard most of the time either. It has been 14 months since the last service. Does this seem wrong to ayone else?
I now have a feeling it is on fixed servicing, despite being told otherwise by the main dealer.
Good point Lummox. I had a mileage of 14,000 in my head taking my driving style into consideration. However, I must be reasonably restrained. Do you think the insurance companies should take note of this?
I may get a discount for being a big girls blouse.:D
31,250 miles in between servicing? I don't care how long life the oil is, that's just wrong!
I thought that on Mk1s it was 20k or 2 years?
my mk1 vRS was seviced at 20K and 37k on variable, now at 51k.
:thumbup:
Why?
Here we go again.......................
I know, I know. As I've said before, I don't care how long the manufacturer specified intervals are - they designed it, not me. I just want to make sure the car sticks to them. :rolleyes:
According to Google, 50,000 km = 31068 miles, so I've actually got less than 1000 miles left :eek:
J
J
That wasnt at you mate.:)
Yeah, but I started this thread knowing that was where it was going to end up :rolleyes:
J
My Passat was last serviced at 106k, its now on 121k with no sign of a service light, which might not be that surprising... however, it absolutely gets its head kicked in sometimes, a proper good hard prolonged thrashing.
Hmmm.
How exactly does the car decide when it needs servicing anyway?
Hmmm.
When you skint.:D
A thermal sensor in the sump sends signals to the dash insert. The sensor measures the quality of the oil as a resistance iirc and this info is sent to the dash insert where a calculation is done with the parameters set into it.
So in theory a car that uses a lot of oil should have a prolonged service interval?
Where as my car uses no oil and is due a service at about 16.5K
My two services on my PD130 have been at just over 18K each so I must be fairly consistent in my driving. The first 18K I got an oil warning light at about 9K this time it has just come on and I've got 600 miles showing to service.
I must admit this whole variable service kinda makes me a little nervous, and I've forgotten to do the brake fluid change at 2 years since the car wasn't serviced doh!
Barney
I still don't understand why a diesel Mk1 should only need servicing every 31k? That must be wrong.
Nope UP TO 31K miles/2 years is what it says in my manual.
Well, Inde-Tech reset the service interval before checking the adaption values, so I have no idea how long it had left. I'll report back in another 30,000 miles ;)
J
