Help Windows XP media player 9
Why am I NOT getting video playback, only a black screen? This is regardless of clip and some I know used to work. Have reloaded media player 9 with no effect! Any ideas?
You might need some extra codecs...have had this myself, but I cant remember where I got them.
Could be DivX, causes all sorts of probs.
Google time )
Only took my about 2 weeks but have traced ut to my video adapter, looks like windows update changed the drivers and it was running on a generic setup!!! DOH!!! Ive been pulling my hair out with this and only when I switched to the analogue port on the card did it it all click as to the problem!
If the clips are divx you would get a black screen and some sounds. Go to divx.com download page
If you get a green screen and sounds then you've got XVID. Go to xvid download page
If your still having difficulties, give us a shout! :thumbup:
Stimps...
I agree with G-spot but WMP9 would say so if it was having problems with codecs.
The problem described would definately be attributed to a video card overlay problem. usual culprit is video acceleration has been turned down/off on the display properties menu or a problem with the video drivers :)
As for codecs. i use K-lite codec pack. has all the best common codecs in one nice package..
also has QT-alternative and RA-alternative. which means you dont have to install the spyware-bloatware laden quicktime and Realaudio stuff.
and media player classic is good too. its a version of WMP without the bloat. :D
