Tyre advice Octy RS
Thanks for the heads-up. Will probably be ordering 4 GSD3's (decided to go for all four at once) from mytyres.co.uk (
Orange is so pass
The Bridgestone S-03s that I've just fitted are very quiet - still running them in though, so can't say much on their grip yet - but already felt some tramlining on a bad surface compared to the 205/55 R16s I had before.
Rondo
the ride is down to the narrower sidewall,and they are much bigger tyres
if the standard car used 205/50/17 then the next closest is 215/45/17 ?
Is it 50% of 205 Vs 45% of 225?
:confused: NO no...225/45 .17 has the closest rolling circumfrence @1935mm....the 205/50.17 has an RC of 1945.......the 215 has 1910mm
catch my drift:D
:thumbup: Phil
According to The Wheel and Tyre Bible 215/45 17s are 1.81% smaller than 205/50 17s - so 70 MPH on the speedo (assuming it's accurate) would be 68.73 MPH on the road.
205/50 - 17 circumference = 2000.56 mm
215/45 - 17 circumference = 1964.44 mm
225/45 - 17 circumference = 1992.71mm
So yes, 225/45 is the best replacement and its chaeper than 205/50 :D
:confused: errrrrrrrr where did you get those figures from?
different from my Michelin data book:cool:
:D Phil
225/45 is a direct replacement for the 205/50 ~ no surprise it's fitted to Leon Cupra / Golf MkIV etc which use the same gearbox / speedo drive etc as the Octy.
Bear in mind that tyres go from apprx 8mm tread (some are 8.5mm) down to approx 2mm when you chuck them, so over the life of the tyre you alter the gearing of your car by around 2%.
Fully worn:-
205/50/17 circumference = 1962 mm
225/45/17 circumference = 1954 mm
Moving to a tyre with a nominal 0.39% gearing change isn't therefore an issuie.
Some octy vRS's where shipped new with 225/45 x 17 . A few of our early members had this tyre size, think it was around early to mid 2002.
