Rocker cover breather pipe
Hi guys,
Been told by my Skoda dealer when I had the cambelt changed that my rocker cover breather pipe needs replacing, is it an easy DIY job and if so could someone help with info on where it is etc
Its a 2002 Octavia vRS
very easy mate - largish hose on the top of the engine connected to the air intake after the filter.
Squeeze that end and the clip comes off. Use a pair of pliers/mole grips to compress the clip on the other end and it's off.
To fit the new piece, dissasembly is (you know the rest).
HTH
Bas
Here's mine done. The old one just crumbled away. Guess the oily vapours kill the rubber. very quick job.
  • 4 years later...
are they expensive? mine has gone all squidgy and soft. what problems could this cause? thanks in advance
that sounds really bad!!!
they cost around ?30 from skoda,if that pipes gone best off checking the pipes under inlet manifold as they go around the same time,good luck :)
Cheers mr G
