Changing the spark plugs
Ethos how long has your been running rough for, out of interest
  • Replies 59
  • Views 5.4k
Well the maf only seemed to properly fail last week, but no idea how long it's been slowly dying or if it just failed one day.
I've been getting a surge on part throttle which is why I changed the plugs (just incase, they needed doing anyway I think).
I will do some more testing on the way home to see if it was the maf causing problems...
So it's running mint now then ?????
No error codes but can't comment on the part surging yet :)
It's not that bad and only happens now and then, see will see if I can provoke it tonight!!!
Sounds good though hope it's ok :thumbup:
It probably won't cure the part throttle surge but iam glad you got it sorted.
Personally i would have tried the Maf first before getting the coils but at least you have some spares.
One of the coils was missfiring anyway so figures I'd replace all 4 at the same time, means I have 3 spare now (they are the L revision).
Going to log 003 and check for missfires on the way to the gym, should all be sorted now!!!! :D
For anyone that cares :D
No missfires and maf was reading about 160g/s @ 5k rpm in 2nd gear.
All is resolved.
All is resolved.
WOOT !!!!
160g/s is good
Did anyone notice the car feels a little bit slower gapped to 0.7mm?
Maybe i'm just getting even more used to the car but it feels a little different since I put the new plugs in. Then again i've had a new maf / coil packs too :D
Running REALLY smooth now tho :thumbup:
