Non Octy Question (Golf Mk4 1.4)
Hi Guys,
I know this is on the wrong forum but I thought I'd as you knowledgeable bunch. And the fact the Mk1 Octy shares alot of engines and parts with the Golf 4.
My brother has a 2001 Golf 1.4, and it seems to be loosing coolant.
There is no water in the oil, and as far as I can see there is no leaks.
One thing I have noticed is there is only a very small trickle of coolant going back into the coolant expansion tank, not the same kind of flow as I get in my Octy.
Any ideas what it could be? Also there is a knocking noise seemingly coming from the top of the engine.
Cheers in advance.
Craig:)
water pump common on the 1.4 i had mine go at 14000miles just over a year old
most likely water pump, went on my 1.6 mk4.
Waterpump... if Cambelt is changed at main dealer every 4 yrs / 60K as per recommendation this should of been changed together with cambelt as one large job.
Would suggest you check if/when this work was done as there may be some warranty on it.
